Post by midlifecrisisrd on Apr 16, 2012 14:42:19 GMT 1
Anybody having problems with this?
Got pwk's with tzr reeds with 10mm spacers.
Bike seems to be running rich on neutral throttle below 5k as it splutters a bit as soon as it stops pulling at small throttle openings, open a little more and pulls clean until it reaches neutral throttle again. Seems perfect and smooth over 5k so suspect pilots still too big ( started at 42 then 40 which improved it massively ) so ordered 38's
Thing is that the carb to airbox rubbers are wet with fuel/oil and there is signs of it creeping out the air pilot screws so seems to be spitting back.
Any one had this when running rich or is it time to order a set of v force reeds and bin the tzr's?
Also considering going to premix as seems really oily at tick over and low revs.
