Post by treppid on Apr 10, 2012 19:53:08 GMT 1
Hi all. Just a question from a rebuilding newbie. That strange black cylinder thing with one cable in and the three cables out, if someone was to, say, go to premix and no longer need the oil pump cable is it actually possible to get inside the black thing and remove said cable? I've had a bit of a go but it appears hermetically sealed, any thoughts? Or is there a better way to operate the two carbs using something else? Cheers......
Post by pepsisteve on Apr 10, 2012 21:30:22 GMT 1
i did that with mine, just popped it apart, took oil pump cable out and then glued it back together. or one of the cable companys will make you one if you ask.
Post by treppid on Apr 11, 2012 19:56:28 GMT 1
Cheers dude, I'll just be a bit more forcefull and invest in some Araldite!!
