iainw
Post by iainw on Apr 7, 2012 12:10:11 GMT 1
When I got the bike back together I put bigger jets in to compensate for the new pipes and tuning. It sarted from cold 2nd kick, ticked over quite well so I spent the rest of the day plug chopping and jetting. Since then it won't start from cold, it needs a bump with the down hill momentum to keep it going.
It fires, runs for a second or two then dies. I think it's a choke problem. When it's running and warm all is OK, it starts first kick. I put the jetting back to what it was when it started OK but the issue is still there.
How does the choke actually work? I know it makes the mixture rich but how, is it so simple it can't fail to work and I should be looking elsewhere? Any ideas? It's a 4L0.
Post by cb250g5 on Apr 7, 2012 12:33:39 GMT 1
Have you put the float bowls on the correct carbs?
Only the lh one has a choke jet in it, so wrong way round, means no choke.
Post by arrow on Apr 7, 2012 17:39:40 GMT 1
Check you have the short rubber pipe fitted between the two carbs.
iainw
Post by iainw on Apr 8, 2012 12:03:08 GMT 1
Check you have the short rubber pipe fitted between the two carbs. The pipe is connected but it was becoming a bit of a sloppy fit, I replaced it with a new piece but still no change. Thanks Arrow. Have you put the float bowls on the correct carbs? cb250g5, you were bang on the money, it started first kick this morning! ;D
Post by Deleted on Apr 8, 2012 23:41:34 GMT 1
whats the difference between the 2 bowls? what do you look for, thanks
iainw
Post by iainw on Apr 9, 2012 0:59:41 GMT 1
whats the difference between the 2 bowls? what do you look for, thanks They both have the brass overflow pipe sticking up but the lhs one has a bit extra casting at the front of the bowl to cater for the choke jet. If you look at them both together it's obvious, though I didn't notice it until cb250g5 said they were different. Have a look at butchers pics here, they're from the lhs carb rdlccrazy.proboards.com/index.cgi?board=mods&action=display&thread=14900 the gasket runs round the choke jet at the bottom, the correct bowl will match it.
Post by Deleted on Apr 9, 2012 3:54:42 GMT 1
thanks iainw, is this what you mean , i pulled both the bowls off and the only difference i could see was on the left hand bowl in the picture it had the extra hole behind the big hole, and the right one doesnt
iainw
Post by iainw on Apr 9, 2012 11:16:21 GMT 1
They look like two lh bowls to me. My rh bowl doesn't have the big hole casting. Maybe someone who's seen this inside of more carbs than me can confirm it.
Post by Deleted on Apr 9, 2012 11:50:54 GMT 1
gday iainw, the one on the left has the hole and the one on the right has the same casting but isnt drilled out, im assuming the left 1 is the left bowl and the other is the other
Post by oldelsieboy on Apr 9, 2012 12:08:16 GMT 1
CHOKE BOWLNO CHOKEOEB
Post by Deleted on Apr 9, 2012 12:17:12 GMT 1
thanks alot oeb, , i got to hand it to you, you have helped me out a few times, have some karma, ken
iainw
Post by iainw on Apr 9, 2012 16:37:10 GMT 1
Interesting. The bowls on mine are completely different, the large hole casting is not there on my rhs bowl, nothing as subtle as thos shown.
OEB, what's the top red ring indicating?
Post by oldelsieboy on Apr 9, 2012 17:19:01 GMT 1
OEB, what's the top red ring indicating? There is a number 2 cast into the bowl similar to the numer 1 that can be seen on the NO CHOKE bowl. OEB
iainw
Post by iainw on Apr 9, 2012 18:52:09 GMT 1
I don't intend on taking the carbs off for some time now as every thing is tickety boo, but next time I'll have a good look at the bowls for markings and take a pick or two. Thanks all for the help and education.
