Post by pepsisteve on Apr 1, 2012 20:57:58 GMT 1
ok, if i adjust the rear brake leaver so it doesnt bottom out on the exhaust i cant start it because the kickstart hits it if i adjust the rear brake leaver so i can start it i have no rear brake ;D has anybody had to re-drill the holes that the pin sits in?
Post by Norbo on Apr 2, 2012 9:12:37 GMT 1
Is your kick start a little bent i havent heared of this before and i have a set fitted to an lc and the kick start misses .
Post by Deleted on Apr 2, 2012 19:51:25 GMT 1
I discovered the same problem when I wanted to turn my build over yesterday for the first time. I have YPVS motor in LC frame.
Post by pepsisteve on Apr 2, 2012 22:22:09 GMT 1
kickstart isnt bent (looks ok) it seems like the adjustment on the height of the brake leaver is in quite big steps, its like it need a hole in the middle of 2 of them. might have a look at tweaking the kickstart though first.
Post by Deleted on Apr 2, 2012 22:27:16 GMT 1
Mines not bent either.
Post by lb on Apr 3, 2012 3:22:15 GMT 1
