Post by flames on Apr 1, 2012 16:45:48 GMT 1
hi dude,i had the same prob on mine,tho dont know if my float valve would fall out without the float bowl on,but the valve was notchy on the float tab and was jamming up and causing both carbs to overflow.i cleaned both carbs out jus to b sure,and blew all the jets out with an airline.the tab on the float bowls i rubbed with some fine wet and dry paper just to smooth out a bit,then rubbed some polish on the tab for good measure.i havent had a problem since.hope this is of some help.
Post by mellow on Apr 1, 2012 17:54:55 GMT 1
my R1 did that today.first start up since last year my 350 does it too.give the carbs a knock with a screwdriver n hammer.probably just stuck float needle
Post by mellow on Apr 1, 2012 22:09:35 GMT 1
at least u can get to ur carbs took f**king ages to strip the r1 to get to the b*****d things
Post by lcowner on Apr 2, 2012 14:01:47 GMT 1
its probablt dodgy float valves paul mines doing the same on 1 side and ive ordered a set of float vlaves
Post by scott on Apr 2, 2012 21:38:53 GMT 1
I've had this m8 and did what flames has said.the hole or slot the needle valve sits in was notchy so rolled up a small piece of wet and dry and worked it round,aukward job m8 but did the trick.
Post by scott on Apr 3, 2012 21:11:49 GMT 1
glad u got it sorted m8.
