webbo
Post by webbo on Mar 29, 2012 13:45:05 GMT 1
Hi, i'm sure this has been covered before but can't find anything searching. I have fitted a new loom but the fitting for the sensor is a bullet and the original on the head is a spade fitting. The thread on the spade fitting is straight and the thread on a bullet fitting sensor is tapered so won't fit. Any ideas?
Post by mellow on Mar 29, 2012 16:22:50 GMT 1
I dont really know the answer m8 but i do know my F2 has a spade on the loom,and on the temp sender......but i bought another temp sender for it and that had a bullet end on it and is tapered Its no biggie to just change the connector to fit
webbo
Post by webbo on Mar 29, 2012 20:56:20 GMT 1
I thought I posted this in the advice section
Post by mellow on Mar 29, 2012 21:18:43 GMT 1
you did ;D
Post by Delbert on Mar 29, 2012 21:42:26 GMT 1
If you dont want to chop your new loom , go to your local car parts store and get a new sender for a 3ltr diesel landrover or discovery cost you about a fiver , should have the male bullet and the same resistance may have the part no somewhere
Post by oldelsieboy on Mar 29, 2012 21:46:40 GMT 1
Hi, i'm sure this has been covered before but can't find anything searching. I have fitted a new loom but the fitting for the sensor is a bullet and the original on the head is a spade fitting. The thread on the spade fitting is straight and the thread on a bullet fitting sensor is tapered so won't fit. Any ideas? Why not make a converter lead with a bullet connector one end & a spade the other OEB
Post by jessy03 on Mar 29, 2012 22:02:33 GMT 1
I think ypvs senders were tapered thread and lc was straight, if you need an lc sender with a spade connector let me know I have 2 spare. Jess
webbo
Post by webbo on Mar 29, 2012 22:19:37 GMT 1
Thanks Mellow!! I like to have the right part for the job and I find it annoying when parts are supereceeded and they don't quite do the same job. very common on older jap bikes. Delbert, do you have that part no?? Cheers.
Post by Deleted on Mar 30, 2012 3:11:51 GMT 1
i just changed the connector to a bullet 1, no worries
Post by midlifecrisisrd on Mar 30, 2012 8:29:50 GMT 1
I had the opposite problem with the head. Mine a YPVS y3 head with tapered head and wanted to use the blade type straight thread.
Had to use the tapered thread bullet one and make a converter wire.
Post by Delbert on Mar 31, 2012 20:48:24 GMT 1
Thanks Mellow!! I like to have the right part for the job and I find it annoying when parts are supereceeded and they don't quite do the same job. very common on older jap bikes. Delbert, do you have that part no?? Cheers. Intermotor 53050 Cheers Delbert
