Post by mellow on Feb 1, 2006 22:53:46 GMT 1
ok all u techies...............how easy it it to change crank seals on an F2? engine splits top/bottom.........so do u lift crank out n put seals in or what as u may b able to tell i never done this b4
kc104
its gripped, its sorted...
Post by kc104 on Feb 1, 2006 22:56:43 GMT 1
really is that simple mate...
Post by mellow on Feb 1, 2006 22:59:37 GMT 1
sum 1 told me u have 2 split the crank
Post by hooligan on Feb 1, 2006 23:01:22 GMT 1
Hi mate you have to split the engine but its quite easy if you have the tools, things to watch are as follows
Clutch basket you need to make or borrow a tool to hold this if not you will brake it
Flywheel you wil need a puller
dont forget have a good look at the crank if its border line change it.
other than that its a doddle just take your time
kc104
Post by kc104 on Feb 1, 2006 23:03:33 GMT 1
if you mean the two outer seals its just a case of lifting out the crank then changing old for new....did it myself recentlly..if you got the manual you should have no probs
Post by mellow on Feb 1, 2006 23:10:12 GMT 1
ok thanks men n yup i got a manual
Post by Norbo on Feb 2, 2006 0:50:00 GMT 1
its not a hard job but it will take a while to do it right . clean all the faces before puting back together . You will be ok . I have pullers if you need 1 for the fly wheel .
Post by mellow on Feb 2, 2006 17:33:52 GMT 1
NORB............yup i will have one off u probably at end of feb.......and im seriously thinkin of one of them lightened flywheels to
Post by mellow on Feb 9, 2006 18:42:28 GMT 1
question time again is there sposed 2 b square bits of rubber stuck to the underneath of the seat at the back on an F2
Post by mellow on Feb 11, 2006 15:20:31 GMT 1
Anyone
Post by pablo on Feb 11, 2006 15:40:10 GMT 1
never ad n f2 meself,seen the rubber blocks on other seats though...gonna check now,got an old lc2 1 ...wait a tick...cor thats cold,nah just 2 springs on that one mate,soz
Post by mellow on Feb 11, 2006 18:55:02 GMT 1
ok thanks for lookin n e way m8 have a warm cuppa
Post by pablo on Feb 11, 2006 22:13:46 GMT 1
i think most bikes have something like that when new but they get lost or drop off as the bikesget older...sounds like your bike must be well looked after,not like some of my old shitters
Post by mellow on Feb 11, 2006 22:15:34 GMT 1
no its been sat n buried in sum 1's garage for 15 yrs ::)i am doin it up......but the seat just seems a bit loose n i dont want it wobblin about wearin the paint of me freshly sprayed frame
Post by pablo on Feb 12, 2006 0:38:04 GMT 1
dont know if they actually sit on the frame do they? i know they hook under the petrol tank at the front,but dont they sit on the seat catches at the back and miss any paintwork?
Post by mellow on Feb 12, 2006 13:08:44 GMT 1
im just off to me shed to put me loom back on so il av a look
Post by mellow on Mar 17, 2006 17:29:01 GMT 1
ok chaps n chapess's its question time again who would just so happen to have a picture of where/how exactly the indicator cancelation unit sits/is positioned im sure one of u has a pic layin around
loopy
Post by loopy on Mar 17, 2006 17:45:11 GMT 1
baggy has got one i think somewhere, If you have a haynes manual...its in there, next page from the torque settings for top yokes. ;D
Post by mellow on Mar 17, 2006 22:23:05 GMT 1
yup thanks loopster wanted bit of a better pic though but i found one on me pc so all is well now but thank u ;D
Post by mellow on Mar 18, 2006 16:40:41 GMT 1
thanks m8 good tip :)was discussing this subject today
Post by mellow on May 26, 2006 19:15:06 GMT 1
me again............do u HAVE TO remove clutch basket to change seals?
Post by pablo on May 26, 2006 19:35:08 GMT 1
bet bloke down the pub will know... ;D
Post by mellow on May 26, 2006 22:19:57 GMT 1
not many replies
Post by pablo on May 27, 2006 0:18:18 GMT 1
alright i'll put you out of your misery...i went in my garage and took my crank out to see if you had to remove the rotor n clutch like you were asking mate,coz thats the kind of guy i am... ...like i thought,the answer is YES...you do have to...the rotor n stator would be in the way of the crank seal even if you could split the cases...but behind the clutch basket there is a little doodad that joins the two crankcases together,i think it holds a bearing in...you can only get to this by removing the clutch...you really should have known... ...hope you appreciate me doing this coz im filthy now...bet you didnt even save me any kebab either...things i do... ...reet,im off to put it all back together i spose... ps oh yeah to clear up the clutch holding thing...you can indeed lock up the clutch with a 2p...but only the outer basket...like hooligan says you'll need a tool to lock the outer basket to the inner one to stop it spinning while you get the big nut off...i made a tool up out of old clutch plates once for a different bike though im afraid...could always try wedging your pecker in there...laters lawnmower man...
Post by mellow on May 27, 2006 10:43:51 GMT 1
dude................if thats true ur a real star ;D didnt take u long then? i hope u used new gaskets and seals when u reassembled ok..............thanks for that info...............really lookin forward to doin this now m8s gonna knock me up a tool to hold clutch basket so should b ok thanks again bert and kebab was lovely and i saved u none ;D i may b at rye tomorrow so get down there n il buy u a tea n cake ;D thanks again
Post by pablo on May 27, 2006 19:27:26 GMT 1
;D no wuckin furrys mate...dunno if its gonna rain tho dude... oh yeah...be careful with the clutch side...you dont wanna get carried away and break any bits off...very easy done...
Post by mellow on May 27, 2006 20:12:27 GMT 1
dude it AINT gonna rain re clutch...........ur just makin me so more wanna do this with comments "be carefull ul break it"
Post by pablo on May 27, 2006 21:14:36 GMT 1
dont say i didnt warn you mate...i broke one misself...on one of me dirtbikes... ...fookin aggro it was...you enjoy yourself... nah with the proper tool to hold the baskets its no biggy...try holding it with your teeth tho...gets harder... ;D ;D ;D
Post by mellow on May 27, 2006 23:37:24 GMT 1
wot teeth ;D
Post by scott on May 28, 2006 20:03:26 GMT 1
mellow,don't forget to lock up the con rods and loosen the nut on the righthand side of the crank m8.i never did this and had to put the casings back together to loosen it because i have'nt got a vice.this was on the rd 250e so don't know if yours will be the same.i had to take that nut off to change the crank seal
