Post by weegiboy on Mar 22, 2012 10:58:49 GMT 1
How Do All
It's been a while but i haven't given up :-) just been away with work then skint :-( , question one , if im not going to have indicators on my build do i still have to have the flasher and relay in the loom to make the circuit complete ? ( electrics is a whole new mine field to me ) . 2 I have fitted the spacers that go in between the back of the cylinder to the back of the carb rubbers , the ones that norbo sells , do i have to put gaskets either side of the spacers ? might sound dumb but im still learning , any help would be appreciated , many thanks weegiboy
ps this weather down here is ace bring on early doors come Sunday :-)
Post by lcrider on Mar 22, 2012 12:12:27 GMT 1
No you dont need flasher and relay if your not fitting winkers . Yes you will need gaskets so you dont get an air leek .
Post by weegiboy on Mar 22, 2012 14:43:25 GMT 1
Thanks lcrider that's sorted that out for me , nice one . wb :-)
Post by midlifecrisisrd on Mar 22, 2012 17:10:50 GMT 1
As lcrider said. I was also led to beleive that if you have no indicators fitted you also have to remove the switch and the writing for it to pass an Mot in case your stupid enough to forget it doesn't have any fitted and you think you are using them Steve
Post by Denzil on Mar 22, 2012 18:51:24 GMT 1
Switch is fine mate. If the indicators are there they must work, if removed then not applicable on the mot.
