Post by Deleted on Mar 15, 2012 12:51:59 GMT 1
i have just replace my clutch but nothing has happened when engageing gears
Post by bigal1 on Mar 15, 2012 13:17:04 GMT 1
have you adjusted the worm screw at the end of the clutch basket
Post by arrow on Mar 15, 2012 18:12:42 GMT 1
Have you got the correct amount of both types of plates ? When you tightened all the clutch bolts, did you feel them compressing the springs ? Did you remember to fit the springs ??
Post by lcowner on Mar 15, 2012 18:59:37 GMT 1
have u got the pressure plate on right
Post by Norbo on Mar 16, 2012 8:36:14 GMT 1
did you make sure the small bearing whent back in at the end of the push rod .
