stuboy
Post by stuboy on Mar 14, 2012 19:23:29 GMT 1
Got some Tarozzi Rearsets for my RD350LC. Using standard swinger but have a problem with how the brake rod and return spring fix. Has anyone got a picture or some advice. Do the rod and spring bot connect onto the one arm and the other one is surplus to requirements ?? HELLLLLLLLP before I go mad
stuboy
Post by stuboy on Mar 15, 2012 17:44:35 GMT 1
Someone must know !!!
stuboy
Post by stuboy on Mar 15, 2012 21:30:07 GMT 1
Sorted. One of the holes was the wrong size and had to be drilled out. Lever arm with 2 holes is spring top hole and rod lower hole with lever facing uowards. Other lever with on hole is for brake light spring.
Post by pepsisteve on Mar 15, 2012 22:45:49 GMT 1
ive just got a set as well mate, had to convert mine to run a hydrolic rear brake, bit of head scratching but got there in the end! completly forgot about rear brake light switch!!
Post by Norbo on Mar 16, 2012 8:33:26 GMT 1
Stuboy . Post some picks of what you did and how it fitts mate may come in handy for others. I can print of and send out with the sets .
