Post by barters44 on Mar 10, 2012 20:07:04 GMT 1
Hi All My 250LC still running rich after rebuild. Symptoms are: lots of smoke, will start first or second kick without choke when cold. plugs dark and wet. wont rev beyond 5000rpm - bogs down. Have checked and set oil pump, then disconected this to run on premix, 32-1, still the same. Have replaced float valves and seats and set float hight, changed main jets for 190 and needles set correct as per manual. air mix screw 1 1/8 turns out. I have dropped bars on and there is no adjustment left at the bars or carbs for the throttle cable, but it ticks over fine at around 1200rpm, however still smokey. has a 275 overbore and 350lc pipes. runs standard airbox. both exhaust smoke the same. what am I missing?
Post by arrow on Mar 10, 2012 20:50:34 GMT 1
How did you reset the ignition timing after the rebuild ?
Post by Norbo on Mar 16, 2012 8:42:52 GMT 1
Just what i was thinking is the timing set correct 1.8 TDC
Post by pepsisteve on Mar 16, 2012 22:03:10 GMT 1
try it with air filter element removed as well
Post by airbraker on Mar 16, 2012 22:52:09 GMT 1
Silly really but you do have the little washers under main jet dont you...... ?
Post by pullmyfinger on Mar 18, 2012 20:35:02 GMT 1
i have the same problem pal i have done exactly the same as you changed coil, cdi, carbs and stator but no differance been told my crank cases may be leaking gear oil through due to a bad seal crank refurbished at grampian i am at a loss too
