Post by brother11271 on Mar 9, 2012 18:58:21 GMT 1
Ladies and gents, I'm a simple person and so computer iliterate that not even sure if hits is being put on the right page. Like most people of my age I'm trying to re-live those early days (some 20-30 yrs ago) so went out and bought a project about a year ago. Getting a rolling frame was the easy bit, full re-build of the rolling chasis, brakes and so on so forth. QUESTION is - I went and bought a 4L1 250 engine. Will the 4L0 350 barrells fit straight on and run as the bike should. Am aware that the carb jets will need to bo up-graded.
Post by marsbar350 on Mar 9, 2012 19:00:11 GMT 1
barrels slot straight on and a 350 head needed ;D welcome by the way
Post by brother11271 on Mar 9, 2012 19:09:29 GMT 1
Thanks for that. Had my head stuck in a Haynes manual for ages trying to figure out what the differance was between the 1981-82 2/350's. Just sounded tooooo easy. Tought there may have been more to it. NOT exactly mechanicaly minded but having fun doing it.
Post by arrow on Mar 9, 2012 19:10:24 GMT 1
Welcome in. You will also need the correct 350 oil pump and its drive. Both are different to the 250.
Post by brother11271 on Mar 9, 2012 19:16:05 GMT 1
Any more tips would be appreciated. And funny enough I have a set of 350 barrells sitting under the stairs. Know of anywhere half decent to send them off for re-boring.
Post by arrow on Mar 9, 2012 19:17:42 GMT 1
Norbo, the admin. on here can sort the barrels mate.
Post by brother11271 on Mar 9, 2012 19:20:38 GMT 1
If you don't ask you don't get lol. I'm only a simple man.
Post by arrow on Mar 9, 2012 19:25:17 GMT 1
If you don't ask you don't get lol. I'm only a simple man. We've all got our cross to bear mate.
Post by marsbar350 on Mar 9, 2012 19:29:06 GMT 1
i let arrow mention the oil pump ;D hes got a soft spot for them
Post by arrow on Mar 9, 2012 19:30:45 GMT 1
i let arrow mention the oil pump ;D hes got a soft spot for them But no spare ones at the moment.
Post by marsbar350 on Mar 9, 2012 19:30:49 GMT 1
butch can you use the 4L1 carbs jetted instead of the 350 ones
Post by brother11271 on Mar 9, 2012 19:41:07 GMT 1
Noting wrong with soft spots. We all have them. I'm starting to favour the soft spot for a good oil pump to, don't want to be running to dry, can't beat plenty of lube.
Post by brother11271 on Mar 9, 2012 19:44:56 GMT 1
Carbs are sitting under the stairs too. Not sure which ones they are, not got round to checking those yet. Whats the best jet, specially if I stick on a set of Gibsons?
Post by arrow on Mar 9, 2012 19:45:26 GMT 1
Have a look on e-bay. The YPVS pump is also the same as the 350lc one.
Post by brother11271 on Mar 9, 2012 19:56:18 GMT 1
Gents, thanks for the advice. It has been a great help. Can crack on with it now and hopefully get the bike out of the lounge sooner rather than later.
