Post by chamber66 on Mar 8, 2012 16:41:45 GMT 1
Just a quickie how much fork oil and what weight is in my F2 forks please. Sorry my manual hasn't turned up yet
Post by mellow on Mar 8, 2012 17:42:56 GMT 1
Oil Capacity (Per Leg) 282cc Oil Level 128.7mm Oil Grade SAE 10W Fork Oil
Post by chamber66 on Mar 8, 2012 21:11:18 GMT 1
Oil Capacity (Per Leg) 282cc Oil Level 128.7mm Oil Grade SAE 10W Fork Oil Thank you very much sir ;D
Post by mellow on Mar 8, 2012 23:04:19 GMT 1
no problem.anything else just ask
Post by bare on Mar 9, 2012 4:39:03 GMT 1
try Mobil 1 atf yess ;-) despite it's oddity it's a V Good shock oil. Several tech sheets place it higher than most bespoke fork oils. Easy enough to try... and discard... if it doesn't please you.
