Post by daglad on Mar 5, 2012 20:43:48 GMT 1
I have dry fitted the oil pump on my 31K and i don't know if its an optical illusion but the bend on the oil pipe seems pretty acute and maybe even kinked has anyone else noticed this?
Post by arrow on Mar 5, 2012 21:22:41 GMT 1
Hi daglad, a picture would help us see whats going on.
Post by Deleted on Mar 6, 2012 0:19:09 GMT 1
gday, with mine it was a tight little bend at the end but it didnt kink, i used the oil line norbo sells , it just squeses thru the pipeline grommet into the case
Post by Deleted on Mar 6, 2012 2:32:36 GMT 1
this is what mine looks like
paulo
Post by paulo on Mar 6, 2012 22:33:41 GMT 1
Hi M8, looks the same as mine and I've had no trouble since rebuild - 510 miles on clock now. One thing i did do is - put some protective sheving over the pipe, were it touches the water pump cover / housing. i think this is a must, as it's only going to wear through in time.
Post by Deleted on Mar 7, 2012 1:13:48 GMT 1
good idea
Post by bare on Mar 9, 2012 16:56:28 GMT 1
haven't seen wear (let alone through) on a few oem that's 30+ year old ones :-)
Post by daglad on Mar 9, 2012 20:30:55 GMT 1
Cheers guys, i have had another look and i am sure its ok, good point about the water pump housing chaiffing (How the hell do you spell chaiffing the oil line though
paulo
Post by paulo on Mar 9, 2012 21:49:02 GMT 1
Most likely just me being a bit over the top, I've had a couple of rubber pipes wear through on my diesel car. Not much chance of any vibration / movement at the oil pump end, but the pipe does touch the water pump and i would hate to f**k the engine through lack of oil - just puts my mind at rest.
Post by arrow on Mar 9, 2012 22:32:23 GMT 1
A length of spring would work well. Would stop any kinking too.
Post by Deleted on Mar 11, 2012 6:26:23 GMT 1
gday arrow, recognize that oil pump?also that big ugly waterpump gasket got replaced when i had to open it up again after i put the water seal in back to front(got destroyed anyway, used some goo to glue it in place), lucky i found a NOS genuine one that told me the right way to fit it,lol
Post by arrow on Mar 11, 2012 12:52:40 GMT 1
Hi Ken, yes I recognise the pump, are you pleased with it ?
