Post by daglad on Mar 1, 2012 23:50:39 GMT 1
No not the green faced japster of smokin fame, but the fine art of masking. My wheels are off for vapor blasting this weekend and as soon as it gets a bit warmer the good old rattle can will be out, so i need some good advice on masking the wheels. I am doing them standard. What is the best type to use, any advice would really be appreciated
Post by steview on Mar 2, 2012 1:18:31 GMT 1
I always try to use 3M products when i am doing any paintwork - the last thing you want is cheap masking tape falling off half way through the job.
Post by Norbo on Mar 2, 2012 13:42:44 GMT 1
I just use normal masking tape
Post by wizard on Mar 2, 2012 20:17:08 GMT 1
Try fine line masking tape, gives you a cleaner edge
Post by Paul Dawkins on Mar 2, 2012 20:36:50 GMT 1
Hand paint gives a better finish.
Post by twostroker on Mar 2, 2012 21:31:23 GMT 1
personly id use 2k or powder coat instead of rattle cans. fine line tape is easier to use and leaves a cleaner edge but you could get away with normal tape if thats all you have to hand
