skidf2
Post by skidf2 on Mar 1, 2012 20:48:26 GMT 1
my f2 keeps blowing fuses :-[noticed the red wire to the regulator/rectifier had no spade connector,so i fitted one.result..blown inline fuse!any ideas
Post by 47x on Mar 1, 2012 21:02:56 GMT 1
seems like a bad earth sumwhere m8,im not that good with electrics,but usually if fuses blow all the time its down to a poor conection or bad earth,chech all connections and spray ub40 on em1.hope u sort it,atb
Post by Tone on Mar 1, 2012 21:35:49 GMT 1
Blown fuses usually mean a dead short somewhere. Does it only blow when the reg/rectifier is plug in ? Remove the tank and see if you can see any wires where it's been touching earth i.e the frame or tank. Possibly the Red wire from the battery.
skidf2
Post by skidf2 on Mar 1, 2012 22:01:59 GMT 1
yes m8,it only blows when plugged in.will look 2 morrow.cheers
Post by 47x on Mar 1, 2012 23:10:20 GMT 1
ah,well must be a a short like tone sed,as i sed not to good on electrics,but only trying to help!!!!!hope u get it sorted,!
