frosty
Post by frosty on Feb 26, 2012 20:26:17 GMT 1
after being layed up in the garage for a couple of years ive been doing abit of tiding up of my 31k today came and cleaned out carbs new battery new fuel dash lights came on powervalve servo opened and closed as it should but it began ticking repeatedly !!!!!!and after kicking over it wouldnt start (good spark thou ) been in the garage all day any ideas or know of anyone in nottingham who could sort it for a good price cheers
cj
Post by cj on Feb 26, 2012 20:40:33 GMT 1
Doesn't sound too terminal (assuming ran at last attempt) I'm kinda under the impression that there maybe one or two around the Nottingham area who can help out
Post by r1beater on Feb 26, 2012 22:52:22 GMT 1
Ask Norbo hes around the village of Nottingham he maybe able to help or know of somewhere!
Post by mellow on Feb 26, 2012 23:47:06 GMT 1
yep give norbs a shout.he knows a bit bout them
Post by 47x on Feb 27, 2012 22:23:43 GMT 1
sounds like maybe crud in fuel tap or carbs? ?
Post by 47x on Feb 27, 2012 22:24:51 GMT 1
give the fuel tap a check m8,u never know?
Post by cb250g5 on Feb 27, 2012 22:25:23 GMT 1
did you put the floatbowls back on the correct carbs, they are different.
frosty
Post by frosty on Feb 28, 2012 0:05:53 GMT 1
yes i did one carb at a time and new fuel and tap is fine
Post by billyboy on Mar 1, 2012 23:57:13 GMT 1
are the plugs getting wet ? or even too wet/ flooding ?
Post by davey on Mar 5, 2012 14:35:45 GMT 1
heat the plugs , put some good fuel down the holes and try ,, never fails for me
Post by bigal1 on Mar 5, 2012 17:43:51 GMT 1
did u put the carb sliders back in the right way as the throttle will be stuck on full and it will never start untill you bump it ..
