Post by treppid on Feb 24, 2012 21:42:12 GMT 1
Hi guys. Just a quick question. Just discovered the unmentioned in the Haynes manual clutch arm needle bearing. I've got the washer and the oil seal out, is there a clever way to get the needle bearing out, it seems well fixed in there! I will be replacing it anyway. Cheers....
Post by bare on Feb 25, 2012 4:32:29 GMT 1
NO, at least not without incurring serious swearing and potential case damage. Are you absolutely Sure ?? that it actually needs replacing? Few do.
Post by dusty350 on Feb 25, 2012 9:07:42 GMT 1
I drifted mine out when I split the cases for a bottom end rebuild.It was an absolute pig to get out and I really butchered it to finally remove it. Easily the hardest part of what is normally a straight forward rebuild. I had the cases vapour blasted so really wanted to remove and replace the bearing along with the gearbox bearings, but I imagine that if it's been well lubricated, it probably wouldn't display too much wear. Depends on how far you want to go.
Good luck
Dusty
Post by treppid on Feb 25, 2012 16:11:58 GMT 1
Thanks all! On second thoughts maybe it doesn't seem that badly worn, think I'll leave well alone for now!! Cheers.......
