Post by liffy16 on Feb 9, 2012 21:03:07 GMT 1
would a carb off a dt125 work on a rd125 mk3 seems to be more secondhand dt carbs around?i have a carb that came with bike but slide ,threaded top ,needle spring etc is missing thanks colin
Post by mellow on Feb 9, 2012 21:50:33 GMT 1
you could always buy those parts new from allens performance or motocarb
Post by Norbo on Feb 10, 2012 12:41:10 GMT 1
They will fit and work but you will need to do some rejetting
Post by liffy16 on Feb 11, 2012 15:55:53 GMT 1
okay thanks for feedback its give me a few ideas also after stator and exhaust any body?
Post by liffy16 on Feb 11, 2012 21:22:57 GMT 1
just found early tzr carb on fleecebay,that might work?
Post by twostroker on Feb 12, 2012 22:39:41 GMT 1
just found early tzr carb on fleecebay,that might work? it will certainly run but i would do a plug chop to give a good indication of if the fueling is set up properly.jetting shouldnt be a million miles out
Post by mellow on Feb 12, 2012 23:43:41 GMT 1
I have the mk3 service manual m8 with all the carb info in if you need all the specs
Post by bigal1 on Feb 13, 2012 16:37:31 GMT 1
i didnt think there was any differance from the lc engine and the dt
Post by mellow on Feb 13, 2012 18:03:40 GMT 1
there is a bit
