Post by lcowner on Feb 8, 2012 11:16:29 GMT 1
can someone tell me what bearings u use to put rgv front on a 4lo - rgv head bearings and 4lo races??? do 4lo head bearings fit the rgv stem? do rgv races fit 4lo headstock?
Post by JonW on Feb 8, 2012 13:49:38 GMT 1
can someone tell me what bearings u use to put rgv front on a 4lo - 4L0 tapered head bearings with a 5m spacer under the lower bearing rgv head bearings and 4lo races??? not that i know do 4lo head bearings fit the rgv stem? - yes do rgv races fit 4lo headstock? - dont think so
Didnt Nikfubar do a 'how to guide' on this? worth looking for. My LC421 build also have some info in it...
Post by midlifecrisisrd on Feb 8, 2012 16:57:07 GMT 1
If the Lc stem is the same as the YPVS then will be Lc taper bearings with the 5mm spacer that can be had from Norbo.
YPVS and RGV bearings have the same inner diameter.
Only bike that takes the rgv bearings is the YPVS 350R
Post by lcowner on Feb 8, 2012 17:49:02 GMT 1
If the Lc stem is the same as the YPVS then will be Lc taper bearings with the 5mm spacer that can be had from Norbo. YPVS and RGV bearings have the same inner diameter. Only bike that takes the rgv bearings is the YPVS 350R Steve aye thanx steve thats handy
Post by JonW on Feb 8, 2012 23:24:56 GMT 1
Didnt in help then? LOL
I fitted LC bearings to mine....
dex46
Post by dex46 on Feb 10, 2012 22:04:45 GMT 1
Hi Mate Lc taper bearings and 5mm spacer under bottom yoke bearing and job's a good un
