Post by Deleted on Feb 8, 2012 9:02:22 GMT 1
gday, i was wondering if anyone can point me in the right direction on what are the correct clearences to rebore the barrels for mitaka pistons? the size will be the 2mm O/S piston,once again thanks
Post by Deleted on Feb 8, 2012 10:20:37 GMT 1
thanks for that headcoats, read it all but it went off topic pretty quick, so am still looking, you would think it would be on the box the piston come in
Post by lcowner on Feb 8, 2012 10:36:52 GMT 1
'bare' on here is ur man
Post by Deleted on Feb 8, 2012 12:08:19 GMT 1
thanks nuts, ware is bare?
Post by Deleted on Feb 9, 2012 21:20:17 GMT 1
well after searching high and low, .060-.065mm is in the w'shop manuel (GENUINE)and i read on another forum the same measurement aswell, so for now that will be it unless i hear differently
Post by bare on Feb 11, 2012 4:13:34 GMT 1
Read the Yama spec for clearance and USE the lowest clearance of that spec. Anything bigger and you Will have problems Trick Now.. is to find a reborer that can actually give you that exact clearance.. And NOT lie about it. Far easier said than done.. unfortunately.
Post by Deleted on Feb 11, 2012 16:06:06 GMT 1
thanks bare, i have to find one (reborer), have a few leads , so .060 it is
