Post by JonW on Jan 31, 2012 7:03:21 GMT 1
So, am I going mad or do my F2 footpegs not work with my F1 pipes? Its like im fitting LC pipes or something, the rear mount is defo not lining up
Post by Shytalk on Jan 31, 2012 9:49:29 GMT 1
So, am I going mad or do my F2 footpegs not work with my F1 pipes? Its like im fitting LC pipes or something, the rear mount is defo not lining up Jon, the basic mounting holes for the hangers to frame and exhaust mount are all the same between the 2 types, the difference is in the rear footrest position, on the F2 type it is about 2 inches further back ( making the bracket longer ) than on the earlier F1 type. So if your problem is with the rear footrests catching that'll be why, the exhausts will fit to the bracket the same which ever hangers you have.
Post by JonW on Jan 31, 2012 10:17:28 GMT 1
Thanks m8!
Hmm, well I will check the silencer flanges, but im defo have a problem getting the rear pipe bracket to get in the rubber bushed hole in the hanger, I'll check the flanges and report back...
