Post by Denzil on Jan 25, 2012 22:58:11 GMT 1
Hi all, I'm Den from Sunny Stoke on Trent!!, I am new to the Forum, having just bought a "basket case". Basically I have a frame with 2 wheels, exhausts (damaged), various boxes of bits, top and bottom case's that match the frame & V5. An engine that has had its barrels removed but has been sitting in water for 5-6 years. I have now stripped the frame/swinging arm and sent that to be painted. I have managed to split the "Water" engine and take the crank out and the berrings sound "nasty" so going to wait until funds allow to send the barrels and crank to be done. In the mean time there is plenty to do with polishing and painting, the forum is brilliant and I have learnt so much from some very clever guys out there. I built a 3 n half elsie about 20 years ago "gosh" from a bag of bits and it was ace. I have had a few bikes in the past even the bike I wish I never sold " Suzuki RG500LC, god I wish I kept that" Anyways, as the title says, where can I get the dog leg collets, little plastic bits that fit over the leg, when I took the swinging arm apart I had to hammer these buggers out, consequently the plastic bits all broke up and got stuck in the arm. Keep up the good work lads, have already sent NORBO an email to order some switch gear transfers. Let the work commence. Attachments:
Post by arrow on Jan 26, 2012 7:53:25 GMT 1
Welcome in denzil.
Post by Norbo on Jan 26, 2012 12:12:37 GMT 1
Holly crap ,mate you have your work cut out for you on this one . But at least you have a helper sniffing around .
Post by Denzil on Jan 26, 2012 18:37:47 GMT 1
Yes thanks Norbo, she likes being with me in the garage. I am confident she will live again!!! well hopefully any way. It wll be a long term project just cleaning everything and renewing were I can. Did you get my email regarding the switchgear emblems?
Post by Denzil on May 7, 2012 16:42:46 GMT 1
Well, I thought I would add a picture or two, wheels powder coated, frame painted, everythin polished, new S/S bolts where shown, new bolts for not shown, everything painted where needed, electrics cleaned, new tyres, brakes bearings etc Couple of questions, where does the reg/rec bolt too, I have a rouge yellow wire where the generator plugs in to by the indicator flasher unit, any ideas? Attachments:
Post by Denzil on May 7, 2012 16:49:50 GMT 1
another Attachments:
Post by Denzil on May 7, 2012 16:54:22 GMT 1
Another Attachments:
Post by Denzil on May 7, 2012 17:01:44 GMT 1
Post by Denzil on May 7, 2012 17:05:00 GMT 1
Post by kennyroberts on May 7, 2012 23:00:35 GMT 1
denzil, im from stoke on trent area.......clayton..., where about are you?
Post by Denzil on May 8, 2012 9:25:15 GMT 1
Post by kennyroberts on May 8, 2012 19:08:56 GMT 1
Slow progress at the moment' but still enjoying it'just dropme a line when u want some help, no problem
Post by mellow on May 10, 2012 10:00:43 GMT 1
hi m8.i did answer about the reg/rect mounting elsewhere. it mount to the frame to the rear of the oil tank at 45 degree angle,behind right hand side panel. i think the red/yellow you are talking about goes to the pass switch.if i remember correctly it plugs in just behind the headstock around the servo area depending how long the wires are
Post by Denzil on May 10, 2012 23:31:42 GMT 1
Mellow, you are a star thanks very much, sorted the RR no joy with the spare wire yet though as have not got a spare to plug in to. Just a quickie though can the side stand switch be bought, I have the cable and the electrics but no switch. Cheers
