Post by scottie58 on Jan 25, 2012 21:05:09 GMT 1
Having just partially stripped my engine I discovered that one of the clutch basket "fingers" has previously been smashed off - 11 remaining Mine is marked 1A004Y51 is one marked 1A003Y32 from a 350 banshee a straight swap?? Quite a few on fleabay - will any from a banshee fit? Also found the idler gear D washer hadn't been fitted and was in the bottom of the cases! - what else will i find?
Post by scottie58 on Jan 26, 2012 7:46:24 GMT 1
Agree with you , will strip the engine completely to check it all and thoroughly clean it before re- assembling. Just need to borrow a puller for alternator.
