Post by Rob50 on Jan 25, 2012 12:18:12 GMT 1
Hi. Im new to this site and 30 years since I owned a 2 stroke. Bought this 350R just before Xmas as a non runner. Lots of fettling with ignition , electrics and it runs well.The problem I need a bit of help with is its spitting water out from somewhere around the rad cap or header tank.. Anyone else had these issues. Was just going to get it running and flog it on but i Luv it and going keep it. all then best rob.
Post by nikfubar on Jan 25, 2012 12:38:52 GMT 1
If it's coming out your header tank then the head gaskets blown mate
Post by Rob50 on Jan 25, 2012 16:12:00 GMT 1
would it not run like a dog with the head gasket blown ??
Post by arrow on Jan 25, 2012 16:24:51 GMT 1
No, not necessarily.
Post by midlifecrisisrd on Jan 26, 2012 9:22:58 GMT 1
would it not run like a dog with the head gasket blown ?? If it's only blowing a little between the cylinder and the water jacket you will notice no difference other than blowing water out the tank. Steve
Post by Deleted on Jan 26, 2012 13:20:06 GMT 1
Is the header/expansion tank overfilled?
Have you had the head off recently?
Is the cylinder head torqued down enough?
Post by Norbo on Jan 27, 2012 23:21:26 GMT 1
Its very simple if you look drain some water out and it has any smell at all like fuel then you know its the head it should have no smell at all and not have any colour in it at all 2 stroke and petrol tends to put a grees layer on top like oil on water if you see what i meen but thats only if its gone a lot .
Mostley a small leak by the sound of it so give it a smell .
Of course if its just the water hacket it may not have gotten to the cylinder yet. but presher in the heared has to be head gasket .
Post by Rob50 on Jan 29, 2012 10:24:37 GMT 1
thanks for advice. New header tank with proper cap and all the hoses justed turned up from ebay for £10.50..bargain..will update to whether a success or whetherv then head needs to come off... thanks again
Post by Norbo on Jan 30, 2012 18:56:04 GMT 1
hat Rob how about a pic of this beast of yours.
