stuboy
Post by stuboy on Jan 24, 2012 23:37:57 GMT 1
Just got new Pyramid Taper bearing set and the top and bottom bearings are identical apart from the fact that one set is 25mm tall and one set is 30mm. Which is the top and which is the bottome set ??
Post by JonW on Jan 27, 2012 6:57:21 GMT 1
Hmm, One should have a smaller inner dia and that is the top one...
Post by LC_BOTT on Jan 27, 2012 18:06:43 GMT 1
I bought some pyramid bearings and threw one in the bin, total rubbush, not enough rollers and the cage was made of cheap tin, fitted them and notchy as hell.
Post by Norbo on Jan 27, 2012 23:15:59 GMT 1
One should have a big holl and one should have a smakk holl the big on the bottom and the small on the top. I know you can get cheep bearings but cheep is crap your better of getting jap and knowing they are good . Never used them befor but if they are like LC-BOT says im not sure id fit them
