Post by loctite on Jan 22, 2012 21:52:33 GMT 1
hi guys just rebuilding banana swinger which way do the needle roller bearings outer cage sit.also what tyres would someone recomend this be a 4l0 conversion ta
Post by midlifecrisisrd on Jan 23, 2012 16:17:34 GMT 1
Don't know about the bearings but tyre wise I think the most common is Bridgestone Bt90's
Think the sporty Dunlop GPR's are getting short now.
You really want a tyre designed for a sports 400 as the Diablo's and other sports bike tyres are designed for heavier bikes so will be hard to heat up on a light bike.
Post by soccersmyth on Jan 23, 2012 20:56:51 GMT 1
Put the bearing in with the flatter part inside so handier to remove if and when you need to.
Fill you're boots with whatever tyres you can get at the best price as you'll never go beyond the capabilites of these more modern tyres. But you'll only get a 150max on the back
Post by loctite on Jan 23, 2012 21:26:26 GMT 1
thanks guys for the heads up much appreciated
Post by midlifecrisisrd on Jan 24, 2012 11:09:06 GMT 1
Put the bearing in with the flatter part inside so handier to remove if and when you need to. Fill you're boots with whatever tyres you can get at the best price as you'll never go beyond the capabilites of these more modern tyres. But you'll only get a 150max on the back Finally got out in the garage and tried a GSXR 400 GK76 rear wheel in the rgv arm. Fits perfect and central but the disc and sprocket faces are approx 5mm further out so with a bigger front sprocket offset ( lc sprocket cover would have to be cut or spaced ( never checked the ypvs one) it should take a 160 rear tyre as the 400 does. You would need to get B and C to make the sprocket as the 400 is 525 pitch. Steve
