Post by chod on Jan 9, 2012 20:23:42 GMT 1
Can anyone tell me what thread the water temperature sender in the cylinder head is? I need to clean up the threads and don't know what tap to use.
Any help is appreciated.
Cheers.
Post by midlifecrisisrd on Jan 9, 2012 20:45:27 GMT 1
Had this problem recently and turns out there are 2 different threads depending on model.
Early ones with the blade type sender had a straight thread where as the later bullet type had a taper thread.
Early sender will not fit in the later head but tapered sender should go in both.
I simply had to use the later sender and all was good. It is a wierd thread but think some one said there wasn't much difference with an M10 x 1.0. Not 100% sure, some one will confirm.
Post by nikfubar on Jan 10, 2012 10:44:11 GMT 1
Yeah it is M10 x 1.0 but it's a taper thread
Post by cb250g5 on Jan 10, 2012 20:45:02 GMT 1
1/8" NPT 27 TPI
Lights blue touchpaper & stands well back.
Post by chod on Jan 10, 2012 22:18:18 GMT 1
Ok thanks. I was thinking it was maybe 1/8 BSPT as the tap seems to start ok but couldnt understand why that thread would be used on a Jap bike. M10 x 1.0 wont even start. Have you used NPT in the past? Thanks.
Post by cb250g5 on Jan 10, 2012 22:43:49 GMT 1
I have an NPT tapered tap & it fits perfectly. Used it to clean out a few heads after having them powdercoated.
The commonly used landy temp sender then screws in nicely.
Post by steveloomis on Jan 12, 2012 17:55:08 GMT 1
Good to know info, thanks
