Post by alext on Dec 27, 2011 20:28:48 GMT 1
ok, having used an FZR400 rear wheel, I need to use a ypvs rear sprocket. I notice from everywhere I look, that the YPVS has a 525 chain and the LC a 530. why??? - why is the more powerful bike with the longer chain got the weaker specification chain?? is there any problem using a 525 on an LC??? where can I get a 525 spec front sprocket for a 4L0?? the slightly thinner chain would help with clearance (yes I know its miniscule, but every little helps) further investigation... would a 520 cope? Ta ALex
Post by oldelsieboy on Dec 27, 2011 21:01:59 GMT 1
ok, having used an FZR400 rear wheel, I need to use a ypvs rear sprocket. I notice from everywhere I look, that the YPVS has a 525 chain and the LC a 530. why??? - why is the more powerful bike with the longer chain got the weaker specification chain?? is there any problem using a 525 on an LC??? where can I get a 525 spec front sprocket for a 4L0?? the slightly thinner chain would help with clearance (yes I know its miniscule, but every little helps) further investigation... would a 520 cope? Ta ALex I think you'll find all the YPVS models were fitted with 520 gauge chain as standard OEB
Post by alext on Dec 27, 2011 23:20:47 GMT 1
so a 520 will be fine for my 4L0???
Post by oldelsieboy on Dec 27, 2011 23:33:34 GMT 1
so a 520 will be fine for my 4L0??? yep OEB
Post by robin on Jan 21, 2012 12:01:58 GMT 1
I'm running a 520 chain on my 4L0, got it fitted when rear disc conversion done last year, no problems with chain stretch or wear, lot better then the monster 530 that was on there.
