Post by petehodges on May 15, 2011 23:35:53 GMT 1
hi all gone down the premix route so whats best for carry oil around with you?? on my endruo i use shampoo btl but that does leak from time to time on that i dont care but dont want oil all over my lc so what you all using lads??
Post by nikfubar on May 16, 2011 0:21:35 GMT 1
It's a pity they don't do those little 1 shot bottles you mix with 5ltrs of petrol like they do for chain saws & angle grinders. You could just take a couple with you in your pocket. I doubt if the oil is good enough quality for our high performance engines
Post by mellow on May 16, 2011 15:41:26 GMT 1
It's a pity they don't do those little 1 shot bottles you mix with 5ltrs of petrol like they do for chain saws & angle grinders. You could just take a couple with you in your pocket. I doubt if the oil is good enough quality for our high performance engines Il have you know nik my stihl chainsaw revs a lot higher than ur bike and for longer ;D
Post by fortypence on May 16, 2011 17:59:23 GMT 1
ok ...here is a simple tip for you all and you will love it!!! Great idea ;D
kas
i dont smoke but me microns do
Post by kas on May 16, 2011 18:51:50 GMT 1
ok ...here is a simple tip for you all and you will love it!!! fit a measuring syringe with 6 inches of clear hose on it and put that under your seat. keep the oil tank on and blank the output pipe off. when you fill up suck out the correct amount of oil from your storage tank with the syringe as you have your mearsurements on the side... then squirt it in your tank!!!!then suck up some petrol to rinse the syringe then back in again!!! it really is dead simple when you realise how easy it is!!! you always have oil in the tank and a clean way to put it in the tank and no messy bottles to leak or run out if you decide to go that bit much further hope you like my tip!!!! now thats what i call tip of the day,cracking idea that "i like it"
Post by petehodges on May 22, 2011 23:15:37 GMT 1
ok ...here is a simple tip for you all and you will love it!!! fit a measuring syringe with 6 inches of clear hose on it and put that under your seat. keep the oil tank on and blank the output pipe off. when you fill up suck out the correct amount of oil from your storage tank with the syringe as you have your mearsurements on the side... then squirt it in your tank!!!!then suck up some petrol to rinse the syringe then back in again!!! it really is dead simple when you realise how easy it is!!! you always have oil in the tank and a clean way to put it in the tank and no messy bottles to leak or run out if you decide to go that bit much further hope you like my tip!!!! good tip that gaz but i,ll have to refit the tank first and make some room in there
Post by Gunny on May 30, 2011 17:18:28 GMT 1
Toppitty tip that
Post by twostroker on May 30, 2011 17:57:40 GMT 1
ive done this before and got through a few of syringes because the petrol ruins the rubber seal in the syringe but its certainly a good idea just get a few syringes as there only cheap. (i got a load for free when my mum worked at a needle exchange). its also ideal for drawing the 2t oil from the 1 litre bottle when mixing fuel at home for a nice accurate mix
perence23
RD350 ypvs
Post by perence23 on May 30, 2011 18:17:40 GMT 1
Right the best way is to get the tropicana orange juice bottles from mcdonalds and fill them up . Its 200ml up to the bottom of the frosted section. We must have 50+ on the shelf at the moment .
Post by lckid on May 30, 2011 18:35:24 GMT 1
ok ...here is a simple tip for you all and you will love it!!! Great idea ;D Second that brilliant!!!
Post by lcowner on May 30, 2011 18:48:53 GMT 1
good idea that gaz,but i cudet be arsed with all that anymore so i put the pump back on!!
jonniebick
Nice Bike...How fast duz it goo mister????
Post by jonniebick on Jun 5, 2011 18:17:01 GMT 1
I never took the pump off in the first place..... I run Motul 710 through the pump and carry a small one shot bottle that came with my chainsaw filled with Castrol R40 under the seat... Smells great and revs like fook.... ;D
