Post by watchhislegs on May 12, 2011 0:01:02 GMT 1
I've just figured that the rear of my F2 frame is slightly bent ie one rail is higher than the other. I never noticed it before asI've not looked at it underneath from the back with the sidepanels on.
I don't want to bin the frame as it has been modified to suit a single sided swingarm.
Any suggestions on how to remedy this?
Thanks
Nico
Post by watchhislegs on May 12, 2011 19:40:51 GMT 1
Had another look at it and it is not super bad; it's still bent though. Thanks for the suggestions above gents. I'm not sure whether a bit of 3x2 would do it, going to ask one of my mates if they have a meaty bit of solid steel. Any suggestions about how to hold the bugger down?
Also, one of the subframe tubes has a split in it near to the shock mount. I assume this will have been cuased when the subframe was bent. Is it safe to assume I just need to weld the seam up after I've bent it back?
Thanks
Nico
Post by watchhislegs on May 13, 2011 20:54:57 GMT 1
Cheers ravedaddy
