Post by petehodges on Apr 25, 2011 23:33:28 GMT 1
Post by midlifecrisisrd on Apr 26, 2011 16:08:35 GMT 1
Had the same kickstart problem on my Lc2 hybrid. Got an alloy kicker on it and had to make up a brake lever without the offset in it.
How much does it hit by, can you cut down the lever toe peg a bit?
Post by petehodges on Apr 27, 2011 8:48:30 GMT 1
Had the same kickstart problem on my Lc2 hybrid. Got an alloy kicker on it and had to make up a brake lever without the offset in it. How much does it hit by, can you cut down the lever toe peg a bit? Steve well i hits it i would say have to take off about 10 mm
Post by midlifecrisisrd on Apr 27, 2011 15:52:08 GMT 1
I'd wait and check again with new kickstart as I thought they were fine with the standard one, are you sure it was a proper lc kicker?
Failing that 10mm should still leave enough of a toe peg.
Post by midlifecrisisrd on Apr 27, 2011 15:55:05 GMT 1
just had a thought, are the footplate mount brackets bent in, this may make the pedal sit further out. If you slacken the bolts and move the footplate out a bit does it clear then?
Post by petehodges on Apr 27, 2011 21:53:14 GMT 1
just had a thought, are the footplate mount brackets bent in, this may make the pedal sit further out. If you slacken the bolts and move the footplate out a bit does it clear then? Steve hi steve ,i get down the garage soon as and give it a go and report back thanks mate
