epic
Post by epic on Apr 5, 2011 12:27:41 GMT 1
I have an allspeed and ramair filter on a rebored 125lc but the main jet in the carb is a std 155 , i can't do a plug chop as the bike needs to be run in before i can give it some so i was thinking of putting the only other main jet i have in , it's number is 240 ,will this be ok for the bike or will it be too big ? i have no idea what order or number the main jets go up in size from std but i know it's better to be rich than lean ... cheer's Paul
Post by LC'Adam on Apr 5, 2011 14:40:51 GMT 1
you want at least a 190 to start with mate, 240 is way too big. Then just come down in 5's with plug chops until its golden brown Don't run it up too much with that 155 in, its way to lean for an air filter Adam
epic
Post by epic on Apr 5, 2011 14:59:11 GMT 1
you want at least a 190 to start with mate, 240 is way too big. Then just come down in 5's with plug chops until its golden brown Don't run it up too much with that 155 in, its way to lean for an air filter Adam thanks adam , do you know where i can get the jets from?
Post by LC'Adam on Apr 5, 2011 15:10:46 GMT 1
Norbo does them or you can get them from YAMBITS on ebay, I would buy a 200 or 210 to be safe to start with but I think once you have done chops you will find that around the 190 mark will be ok Still, don't risk it, always, always plug chop other wise disaster is imminent ;D You got a 10w carb then I presume and a later type allspeed? Can we get pics? Adam
epic
Post by epic on Apr 5, 2011 15:12:46 GMT 1
I'VE FOUND THE JET NEEDED AT YAMBITS
epic
Post by epic on Apr 5, 2011 15:18:16 GMT 1
Norbo does them or you can get them from YAMBITS on ebay, I would buy a 200 or 210 to be safe to start with but I think once you have done chops you will find that around the 190 mark will be ok Still, don't risk it, always, always plug chop other wise disaster is imminent ;D You got a 10w carb then I presume and a later type allspeed? Can we get pics? Adam I got a carb off ebay that was said to be off a 125lc but it had this large jet in it and the numbers on the body started with t4 so i think it was off a tzr maybe??? i've ordered a 190 off yambits but i'll get a few larger ones aswell as i can't do a plugchop until the bike has been run in , that could take all summer i'll post some pics when i can but she looks really rough at the mo as the bodywork needs a pro paintjob . i'm going to go for a kenny roberts mustard yellow scheme
Post by bertiemollie on Apr 5, 2011 18:08:01 GMT 1
Just be carful, if you have a 12a carb then you will need around a 220. I have run a 240 before and it ran OK, just a bit crisper with 220.
If you have a 10W carb unrestricted carb then 155 is std. and the main jet size needed will be smaller. This may well be what you have so just make sure you check.
epic
Post by epic on Apr 5, 2011 18:22:45 GMT 1
Just be carful, if you have a 12a carb then you will need around a 220. I have run a 240 before and it ran OK, just a bit crisper with 220. If you have a 10W carb unrestricted carb then 155 is std. and the main jet size needed will be smaller. This may well be what you have so just make sure you check. the carb with the 155 main jet is a 12 a that's the one i have on the bike now the other carb is a t4 something or other and that one has the 240 jet in it i really want to run rich until the engine has been run in then i can chop and change if needed ...
Post by LC'Adam on Apr 5, 2011 18:26:22 GMT 1
Yes as bertiemollie says epic, because you have a different carb I am unsure of what would be a good starting point I assumed you had a 10w, Please be careful mate, I don't want to have caused you a meltdown. Standard air box is much easier to jet for. Some one will be along soon that can give the best advise, I have a 12a carb you could buy if needs be. Adam
epic
Post by epic on Apr 5, 2011 18:39:12 GMT 1
can't you lot read or something lol I have a 12 a carb with the std jet that comes with it, ie the 155 but i presume i have to up-jet to accomadate the airfilter and the allspeed, i thought i might have to account for the rebore aswell but wasn't sure.The last thing i want is to run lean after spending close to 300 quid on the rebuild ...
i'm getting confused now , lol
epic
Post by epic on Apr 6, 2011 11:32:04 GMT 1
10w carb...standard jet is 155....upjet to 190 with a ramair... 12A carb...standard jet is 195....upjet to 230/40 with a ramair with a standard airbox... 10w carb upjet to 170/80 12A carb upjet to 210/20 hope this clarifies things!! cheers gary , i'll go with the 220 i have and see how it goes if it doesn't feel right ill get a 240 , btw should i adjust my oil pump aswell ? at the moment i'm doing a premix but when i sort everything out i want to use the autolube . could you tell me how to adjust the pump and by how much to go with the 220 jet and the 240 if i need it... cheers paul
epic
Post by epic on Apr 7, 2011 13:28:26 GMT 1
can someone tell me how to adjust the oil pump ? is it the disc part you adjust or a screw ?
Post by LC'Adam on Apr 7, 2011 14:09:31 GMT 1
Adjust the pump cable with the adjuster that screws into the clutch cover. The more tension you put into the cable the more oil gets pumped in. Get yourself a genuine manual mate, it will tell you everything you ever need to know Adam
epic
Post by epic on Apr 7, 2011 18:51:13 GMT 1
Adjust the pump cable with the adjuster that screws into the clutch cover. The more tension you put into the cable the more oil gets pumped in. Get yourself a genuine manual mate, it will tell you everything you ever need to know Adam i have the manual adam but it's in japanese ;D
epic
Post by epic on Apr 11, 2011 8:54:41 GMT 1
haynes on ebay from £5 mate... i'm ahead of ya gary ,got one comming as the more i strip the bike the more bodges i'm finding was hoping my savings would go on a nice paintjob through norbo but it looks like i have a whole lot of other things to do first
