Post by billy on Mar 29, 2011 20:43:41 GMT 1
The footrest hanger mounts on the frame is bent inwards so the aluminum hangers are quite close to th swinger. There's even an old wear mark on the left side so obviously it needs to be bent out a tad. But, I need to know how much gap there shall be between the aluminum hanger and the swinger. PS: I know it's impossible to say exactly how much gap there shall be down to the last millimeter, (these bikes probably came out a differently from factory anyways) but maybe we can come up with a reasonable approximation.
Post by lcowner on Mar 29, 2011 20:54:39 GMT 1
are both sides bent ?u can take measurment off the other side ,no?
Post by billy on Mar 29, 2011 20:56:35 GMT 1
are both sides bent ?u can take measurment off the other side ,no? Well, not sure tbh, I need to put an engine and a swinger in to check. All I know is that at least one side is out of whack.
Post by mellow on Mar 29, 2011 22:17:47 GMT 1
just kneel directly behind it and see if it looks str8.should be able to see.If not just bend it till it does......could run downstairs n measure mine
Post by mellow on Mar 29, 2011 22:23:51 GMT 1
about an inch m8
Post by billy on Mar 30, 2011 3:20:52 GMT 1
Thank's mate. I suspected they should be straight but who knows lol.. The gap/s are way smaller then an inch anyway, it's more like.... almost touching the swinger. ;D
Post by mellow on Mar 30, 2011 15:17:19 GMT 1
thats where i measured from
Post by billy on Mar 30, 2011 16:34:52 GMT 1
Thank's again boys, very helpful!
Post by billy on Apr 1, 2011 3:50:45 GMT 1
il measure mine mate from the ends of the hangers as mine is built on a NOS frame so i know it aint been dropped...but clearance is about an inch ish from peg rear mount hole to swinger. A daft question maybe but did you measure at the upper or lower swinger tube?
Post by mellow on Apr 1, 2011 20:58:28 GMT 1
roughly............with lower arm bit m8
Post by billy on Apr 2, 2011 0:36:16 GMT 1
Thank's again. I made a stupid mistake yesteday, I thought I could carefully bend the thing back by simply pulling the aluminum part out. Well........ it didn't work. As I pulled, I suddently heard a pinging sound. WTF was that?? Oh nooo the bloody footrest hanger cracked! Luckily it was a spare one and not a mint one, still sucks though. I managed to bend the frame mount out a bit though so at least the bolt for the rear footpeg isn't as close to the swinger anymore. Guess it'll have to do.
Post by mellow on Apr 2, 2011 11:18:38 GMT 1
i knew u was gonna say that when i started reading ;D careful m8,alloy is soft and with that leverage ul snap the hanger...oh...u already have ;D ive snapped the back end off one before just undoing a rear footrest nut I wouldnt worry as long as nut doesnt foul swinger
Post by mellow on Apr 2, 2011 11:20:21 GMT 1
Post by lcowner on Apr 2, 2011 17:06:20 GMT 1
day sha vu........
