Post by case on Mar 10, 2007 23:47:44 GMT 1
what forks and yolks fit a 4l1 frame if i was to try build a special thanks in advance for any info ;D
Post by Dirtbag on Mar 11, 2007 8:36:19 GMT 1
I think Vin and KC would be the best ones to ask about this conversion mate...................PM them
Post by mellow on Mar 11, 2007 12:26:56 GMT 1
wot ya need m8 is a BIG pair of harley forks...........superstupidlylong with real uncomfortable impracticle bars...mod them n turn em upside down thats all my knowledge done for now ;D
Post by case on Mar 11, 2007 12:37:47 GMT 1
what one er them hardley moveing sons ;D ;D ;D ;D
Post by vin on Mar 11, 2007 13:16:00 GMT 1
Ive not much experience with 4L0/1's but I do know anything is possible ;D but none are a straight swap without some modification It would probably be a stem swap or in some case's if RGV a simple 5mm spacer under the bottom headstock bearing! A stem swap on my RD YPVS/FZR400 front end was pretty easy as I was lucky enough to be able to use a 10 ton press at work. All was needed was to machine the weld at the base of the stem out,press the FZR stem out,press the RD stem in and re-weld the base! My RGV conversion was even easier as it was just the 5mm spacer and job done ;D So it really does depend on which front end you want to fit, but keep in mind the bigger the bike, the heavier the springs and setup are so you may have to fork out (no pun intended ) on some lighter springs if going for a larger bike front end! Hope this helps a little
Post by case on Mar 11, 2007 14:55:28 GMT 1
cheers fella will prob go the easiest way as this will be my first go at this type of build (headscratching)
Post by vin on Mar 11, 2007 15:02:06 GMT 1
always someone on here that will help if you get stuck
