russktm
Finally on the road!!
Post by russktm on Feb 21, 2007 1:24:28 GMT 1
i'm sure i read a thread about which sealant to use on the two crankcase halves, i've been looking but i can't find it!!! any how is blue hylomar ok? i know you can't use silicon as its too thick and your crankcases don't mate properly! what's anyone else used?? and which is best?? ta, russ. ;D ;D
loopy
Post by loopy on Feb 21, 2007 3:41:18 GMT 1
ICI high temp sealant available from most shops like b and q.... (designed for fitting cooker hobs... tested to 300 deg c
hylomar is good but what they dont tell you is you will need to re do it after 12 mnths cos it rots like a gud un, prob cos its over hydrolysed
Post by bare on Feb 21, 2007 4:40:15 GMT 1
YamaBond is the prefered stuff ..Dealer sells it.. Slightly Cheaper is Threebond.
Post by mellow on Feb 21, 2007 17:21:41 GMT 1
tiny bead of blue hylomar i used shouldnt matter if it "rots" coz there shouldnt b a huge cavern to fill. if u choose to use yammabond good luck findin sum from a uk dealer and i believe its about £40
Post by bare on Feb 21, 2007 17:25:42 GMT 1
Unbelievable.. you guys on that Island are Overcharged on everything.. Yamabond is like $10 Mail order Threebond then Google it.
Post by mellow on Feb 21, 2007 22:09:46 GMT 1
where u from then m8? when i was doin mine i asked the main yam dealer for it and they wanted the part number for it they should know that the only place i could find it was sumwhere abroad at about £40
