Post by twostroker on Feb 19, 2007 21:16:53 GMT 1
has any body tryed that petrol tank sealant stuff advertised in classic motorcycle mechanic's magasine?it looks like fibre glass resin and i think its about £30. the reason i ask is my mk1 125lc tank has a slight leak,undernieth what i thought was surface rust is atcualy porus rusty metal.im not sure if to risk trying the resin stuff or just replace it? im a bit gutted realy as i recently re-sprayed it and laqured all the decals in.
Post by scott on Feb 19, 2007 21:49:32 GMT 1
i used a 2 pac filler on mine called leak fix.got it from focus d.i.y. mine were just a couple of pin holes tho m8. heres another tank sealant called petseal but don't any 1 whos used it. www.tankcareproducts.co.uk/
Post by hooligan on Feb 19, 2007 22:05:44 GMT 1
www.frost.co.uk do a complete system to clean derust and seal your tank I used it on my Valve and it hasnt had any problems since.
Post by twostroker on Feb 19, 2007 22:10:09 GMT 1
does that leak fix go inside or out side the tank?
Post by scott on Feb 19, 2007 22:15:50 GMT 1
it's like a body filler that goes on the outside of the tank which can be sanded,painted,drilled and tapped. but the holes i fixed were just pin holes m8 and i don't know how long it will last
Post by twostroker on Feb 19, 2007 22:19:06 GMT 1
i think i will go for the frost restoration one as its been try ed and tested,cheers for your help guys,much appreciated
kc104
its gripped, its sorted...
Post by kc104 on Feb 19, 2007 22:25:37 GMT 1
dont use petseal....it cracks and breaks up after time. I used the aircraft spec stuff from tankcareproducts....its a bit like red treacle that you pour into the tank, swish it about a bit then allow it to harden. Worked a treat on my tank....took ages to cure though but worth the wait. Recommended.
Post by mellow on Feb 19, 2007 22:31:36 GMT 1
i used the rust converter from tank care place...............and i got a tub of Flowliner to go in me 125 tank soon
Post by twostroker on Feb 19, 2007 22:42:27 GMT 1
kc104,with the red treacle type stuff from tank care products,did you use the cleaner they sell to clean the petrol residue out first?
im glad that people recomend these type of repairs as clean tanks arnt easy to come by and i dont want to paint another tank.
burner
Post by burner on Feb 19, 2007 22:45:57 GMT 1
Have used the frost sealer a few times and has never let me down mate...........
Post by mellow on Feb 19, 2007 22:52:56 GMT 1
it is worth treatin with the rust converter though u dont wanna seal in rust do ya its good stuff to............strips concrete and is reusesable
Post by twostroker on Feb 19, 2007 22:54:41 GMT 1
frost sealer it is then,my tank hasn got any visible holes,its just started to go porous so fingers crossed should be OK obviously the sealer goes inside,is it worth rubbing the rust down underneath and painting it in red oxide or zinc rich primer to slow the rust down,i don't want to rub it down too much in-case its like a sieve!
Post by mellow on Feb 19, 2007 22:58:57 GMT 1
id wire wheel it down to bare metal m8...........like i av been doin today. ok..............u may find sum holes but if u just leave it and hope........and paint over it........it will still rot out wire wheel it............treat the rust...........sort out holes if there are any then seal. im an expert on leaky tanks m8.........ask anyone ;D
Post by twostroker on Feb 19, 2007 23:19:08 GMT 1
if i find any holes will the tank sealer fill them of just leak out? have you used it on a tank that is badly rotton? i would like to make a nice job of it,bare metal,etch,re paint it underneith,just a bit worried of wire wheeling it to find tin foil thick metal with holes like a tea bag
Post by Dirtbag on Feb 19, 2007 23:19:32 GMT 1
There is a company that can do a prestige job....its guaranteed for life.............but sets you back £150
Post by mellow on Feb 19, 2007 23:27:32 GMT 1
hartlepool radiators.theres a thread on here for fuel tank repairs. as for the holes.depends how big they are.id still rub it right down.best to find out wot its like n sort it instead of paintin n hopin
Post by nuttytart350 on Feb 19, 2007 23:29:20 GMT 1
yup donk ... i emailed em on saturday about my tank ...
Post by twostroker on Feb 19, 2007 23:34:19 GMT 1
i would love to let some one else make a better job of it than i possably can, but for £150 i would rather find another tank and paint it my self to match the rest of the bike,its probaly worth it on tanks that are very old and very rare, unless its a job that i clearly cant do 99% of the time i try to do it my self to keep costs down,ive messed a few jobs up but i always think if you dont attempt it you will never know cheers any way ;D ;D
Post by mellow on Feb 19, 2007 23:37:33 GMT 1
yes m8 thats one way of thinkin but..............tryin to find a decent tank is gettin harder.i had about 5 that looked ok till u cleaned the surface rust up i almost had the work done by the company but luckily i got a good tank in the end
Post by mellow on Feb 19, 2007 23:39:38 GMT 1
Post by K.B on Feb 20, 2007 20:05:55 GMT 1
The best way to repair the tank is to sand blast the tank then weld up any holes, then seal the tank with a tank seal then prime and paint the tank. Thats the proper way its done.
Post by mellow on Feb 20, 2007 23:06:49 GMT 1
on a lighter note...................while askin a bloke for a quote to weld my tank.............i said "its got about 10 tiny holes in it m8 that need weldin up".........................."well it must have sum rust in it then "he says no shit sherlock ;D
zebrd
Time for Bed!!
Post by zebrd on Feb 22, 2007 12:19:15 GMT 1
Ive used flowliner on two tanks now and it has worked perfectly. It is very good.
Ive heard petseal doesnt last and eventually cracks and your back to square one.
Post by mellow on Feb 22, 2007 16:52:22 GMT 1
hi zeb...........did u tip excess flowliner out after coating or just leave it all to set in the tank? oh yeah.............PETSEAL IS POOH!!!! breaks down
Post by sulli on Mar 1, 2007 14:06:25 GMT 1
the best way is to clean the tank, strip it back identify the rusty holes. drill them till you get clean metal weld the holes up. treat with a rust converter and then apply your favourite sealer paint and finish its a long process but worth it for peace of mind
Post by Dirtbag on Mar 1, 2007 16:23:38 GMT 1
Dodgy thing though welding fuel tanks................where the metal has rotted and gone very thin....it'd be a pointless task trying to MIG weld it.
Oxy/acetylene set would be much better.........but.......the tank needs to have been empty and dry for some time.
Most people solder or braze the tank.....my personal preference would be brazing.
I remember in the 80's there was a company that made ABS plastic tanks for LC's.....you could hardly tell them from the originals.
I have asked before on here about them , but no-one can shed any light on it. A friend of a friend had one on his 350 LC racer.
Post by mellow on Mar 1, 2007 17:28:04 GMT 1
Post by nuttytart350 on Mar 1, 2007 21:35:07 GMT 1
an mine is now at hartlepool radiators for a full seeing to ...
Post by vin on Mar 1, 2007 22:32:41 GMT 1
Have used the frost sealer a few times and has never let me down mate........... me too
Post by pablo on Mar 2, 2007 22:01:35 GMT 1
you'll want to use petrol in it though mick ;D
