Post by scott on Feb 3, 2007 21:51:09 GMT 1
ha .... at least mines one better .... said it was a jetski .... ;D so what ya sayin i'm up shit creek without a paddle ;D lol ;D ;D
Post by nuttytart350 on Feb 3, 2007 21:51:37 GMT 1
Interesting start. Discs look like they are aquiring terminal rust tho / Front fender is damn near destroyed / Lotsa rusty bits evident in there. 1 .... discs are brand new but have been in and out of a workshop for a month or two 2 .... the "rusty bits evident" are in fact where the welding and cutting has been done on the frame / spannies / side stand etc All this is SO just on the surface that it can be wiped off with a scouring pad i use for my non stick frying pan 3 .... front fender is sound but very dirty / the black line near the front is infact some plastic welding done profesionally because of a small crack / it only looks bad against the white paint / if you saw it in the flesh you would have realised that Finally tomorrow the whole thing is being stripped to the last nut n bolt an distributed to all the right people for sand blasting / powdercoating / painting etc and on the re-build will be treated to stainless nuts bolts and fasteners If you had been a member of this site for long enough you would have seen pics of my 1340cc bandit special i built over 4 years that had won awards for both technical as well as quality workmanship ..... i dont put together or run any bike that would either break or fall apart .... this is "the start" of a hybrid not the finished product WATCH THIS SPACE
Post by tonkatoy on Feb 3, 2007 21:55:16 GMT 1
donk said mine was a canoe Sorry mate no probs mate just not stopped cryin since you mentioned it ;D
Post by scott on Feb 3, 2007 21:55:20 GMT 1
Interesting start. Discs look like they are aquiring terminal rust tho / Front fender is damn near destroyed / Lotsa rusty bits evident in there. 1 .... discs are brand new but have been in and out of a workshop for a month or two 2 .... the "rusty bits evident" are in fact where the welding and cutting has been done on the frame / spannies / side stand etc All this is SO just on the surface that it can be wiped off with a scouring pad i use for my non stick frying pan 3 .... front fender is sound but very dirty / the black line near the front is infact some plastic welding done profesionally because of a small crack / it only looks bad against the white paint / if you saw it in the flesh you would have realised that Finally tomorrow the whole thing is being stripped to the last nut n bolt an distributed to all the right people for sand blasting / powdercoating / painting etc and on the re-build will be treated to stainless nuts bolts and fasteners If you had been a member of this site for long enough you would have seen pics of my 1340cc bandit special i built over 4 years that had won awards for both technical as well as quality workmanship ..... i dont put together or run any bike that would either break or fall apart .... this is "the start" of a hybrid not the finished product WATCH THIS SPACE i saw ur bandit
Post by nuttytart350 on Feb 3, 2007 21:56:32 GMT 1
ha .... at least mines one better .... said it was a jetski .... ;D so what ya sayin i'm up shit creek without a paddle ;D OR A CANOE .... ;D
Post by tonkatoy on Feb 3, 2007 21:57:09 GMT 1
Interesting start. Discs look like they are aquiring terminal rust tho / Front fender is damn near destroyed / Lotsa rusty bits evident in there. 1 .... discs are brand new but have been in and out of a workshop for a month or two 2 .... the "rusty bits evident" are in fact where the welding and cutting has been done on the frame / spannies / side stand etc All this is SO just on the surface that it can be wiped off with a scouring pad i use for my non stick frying pan 3 .... front fender is sound but very dirty / the black line near the front is infact some plastic welding done profesionally because of a small crack / it only looks bad against the white paint / if you saw it in the flesh you would have realised that Finally tomorrow the whole thing is being stripped to the last nut n bolt an distributed to all the right people for sand blasting / powdercoating / painting etc and on the re-build will be treated to stainless nuts bolts and fasteners If you had been a member of this site for long enough you would have seen pics of my 1340cc bandit special i built over 4 years that had won awards for both technical as well as quality workmanship ..... i dont put together or run any bike that would either break or fall apart .... this is "the start" of a hybrid not the finished product WATCH THIS SPACE you tell him girl ;D
Post by tonkatoy on Feb 3, 2007 21:58:36 GMT 1
OR A CANOE .... ;D
either way i'm f****d ;D ;D ;D
Post by mellow on Feb 3, 2007 22:05:11 GMT 1
Post by nuttytart350 on Feb 3, 2007 22:12:22 GMT 1
i saw ur bandit...slow pile of pooh it was ;D U R SO DEAD .....
Post by mellow on Feb 3, 2007 22:20:36 GMT 1
yeah u r SOOOO strippin ur own rusty bike 2 mora n doin ur own polishin ;D ;D
Post by Dirtbag on Feb 4, 2007 5:11:45 GMT 1
Sorry mate no probs mate just not stopped cryin since you mentioned it ;D Row , row , row your boat , gently down the road ;D
Post by tonkatoy on Feb 4, 2007 20:09:35 GMT 1
no probs mate just not stopped cryin since you mentioned it ;D Row , row , row your boat , gently down the road ;D ;D ;D ;D
Post by alibongo on Feb 5, 2007 16:46:58 GMT 1
Interesting start. Discs look like they are aquiring terminal rust tho / Front fender is damn near destroyed / Lotsa rusty bits evident in there. Finally tomorrow the whole thing is being stripped to the last nut n bolt an distributed to all the right people for sand blasting / powdercoating / painting etc and on the re-build will be treated to stainless nuts bolts and fasteners If you had been a member of this site for long enough you would have seen pics of my 1340cc bandit special i built over 4 years that had won awards for both technical as well as quality workmanship ..... i dont put together or run any bike that would either break or fall apart .... this is "the start" of a hybrid not the finished product WATCH THIS SPACE I saw your Bandit, very nice too. Altho, it seemed to be a "no-expence spared" bike and this looks as if its goin the same way....... Methinks young Clurre has a big pit of money somewhere, whatcha doin later? ;D
Post by mellow on Feb 5, 2007 18:40:20 GMT 1
buyin me a miccy d's hopefully ;D
Post by alibongo on Feb 6, 2007 16:43:26 GMT 1
Damn! Missed out there!! ;D
Post by mellow on Feb 6, 2007 17:53:53 GMT 1
not yet m8 still aint got it ;D
Post by alibongo on Feb 6, 2007 18:04:49 GMT 1
Might have a Big Bite special kebab 2nite.
Post by nuttytart350 on Feb 6, 2007 21:36:31 GMT 1
buyin me a miccy d's hopefully its comin .... thats a promise ....
Post by mellow on Feb 6, 2007 21:39:29 GMT 1
so is xmas...........bread n water again 2 night
Post by nuttytart350 on Feb 6, 2007 21:43:20 GMT 1
ahhh bless ....
Post by Dirtbag on Feb 6, 2007 23:03:05 GMT 1
Yeah....poor old Mellow.......he must be on the bones of his arse.......asked me for a bucket of sand yesterday
Post by mellow on Feb 6, 2007 23:03:48 GMT 1
still waitin for it to m8
Post by Dirtbag on Feb 6, 2007 23:15:41 GMT 1
Do you want me to mix a bit of Loopy's breast milk into it ?.....make it go a bit further ? ;D
Post by mellow on Feb 6, 2007 23:17:12 GMT 1
yeah why the hell not ;D
Post by alibongo on Feb 7, 2007 18:09:56 GMT 1
WTF!?!?!?
Post by Dirtbag on Feb 7, 2007 18:17:36 GMT 1
;D ;D
Post by mellow on Feb 7, 2007 19:48:25 GMT 1
???whassup
Post by Dirtbag on Feb 7, 2007 19:52:18 GMT 1
I think the sand put him off ;D
Post by nikko on Feb 7, 2007 21:07:44 GMT 1
HuHU , nice job so far , somes likes , other dont but , in my opignion , have to show respect to the job made . Im proud to know person such inventive .
Nikko wish I was so inventive ...
Post by nuttytart350 on Feb 7, 2007 22:00:43 GMT 1
thanks nikko ... if it turns out like i imagine it in my mind ... i will b pleased ....
