von
Post by von on Sept 9, 2006 13:43:00 GMT 1
Bad luck m8.Just tells your son ,better start reading them haynes manuals before the maths books ;DAt least a Two stroke aint hard to fix compared to a mashed up top end Four stroke.I know m8 Me gsxr went Pop well BANG ;D.Think on the bright side m8 at least you never locked the back wheel with your boy on the back.
Post by chrismac on Sept 9, 2006 13:52:06 GMT 1
Bad luck m8.Just tells your son ,better start reading them haynes manuals before the maths books ;DAt least a Two stroke aint hard to fix compared to a mashed up top end Four stroke.I know m8 Me gsxr went Pop well BANG ;D.Think on the bright side m8 at least you never locked the back wheel with your boy on the back. True, True but still a bugger
Post by chrismac on Sept 9, 2006 13:53:55 GMT 1
judging by the pre ignition on the piston Hooligan what can you see that tells you this? I just sore lots of bits of metal and a f**k engine What does pre ignition look like? How do you know when your getting it? I did a plug chop thingy and all looked OK!!
Post by Deleted on Sept 9, 2006 14:19:52 GMT 1
it looks well fubared have you nseen the pics of mine my mate said dont worrie itll only be a top end build but as you no stuffs like rocki horse shit so ended puttin in ypvs , anyway good luck matey!!!!!!
Post by chrismac on Sept 9, 2006 20:48:21 GMT 1
Cheers m8 ;D sore what was left of yours at Norbos I'm going to rebuild mine Need to get some money from somewhere but cleaning a few bits up ready. Got a beed blasting cabinet from my mate going to get the cases shiney ;D while I save
Post by Deleted on Sept 9, 2006 22:08:04 GMT 1
mmm nice shiney parts all over then!! are you going lc or ypvs then? ;D
Post by chrismac on Sept 9, 2006 22:53:22 GMT 1
stayin standard
Post by mellow on Sept 10, 2006 8:20:00 GMT 1
STANDARD AND CLEAN!!! good boy chris thats the way to go ;D
Post by alibongo on Sept 11, 2006 11:10:02 GMT 1
Bath plugs are best, keep the water out! ;D
Post by hooligan on Sept 11, 2006 12:09:18 GMT 1
Hi Chris
when your crank twists its always the oil pump side that goes. the flywheel side will always stay correct in terms of ignition timing. What hapens regardless of the type of plug used is the right cylinders timings out and the piston is in the wrong place when the plugs fire. on one of your photos you had a big dip in the piston and your crank bearings are shot you dont normally get a massive faliure like that with faulty plugs at worst the piston will hole.
hope you get it on the road again soon
Post by hooligan on Sept 11, 2006 13:02:06 GMT 1
Hi chris
just seen the bit about the blast cabinet, they come up realy well but be prepared to spend a long time cleaning the cases out the glass gets everywhere. Took me hours and Im still going to flush the engine out when its built
Post by chrismac on Sept 12, 2006 20:59:41 GMT 1
bit of a set back on the blast cabinet!! the compressor was 110v but he didn't have a transformer anymore, I did but only a small 1 after about 5 mins it blows the fuses on the transformer. Need a bigger one
Post by hooligan on Sept 12, 2006 21:15:10 GMT 1
No you dont just take the fuse out and bung a bolt in It might catch fire though Disclaimer Dont take any of Holigans electrical advise seriously if you do it will all end in tears
Post by nuttytart350 on Sept 12, 2006 21:22:27 GMT 1
;D ;D ;D
Post by chrismac on Sept 14, 2006 23:22:35 GMT 1
Post by pablo on Sept 14, 2006 23:50:59 GMT 1
;D...wondered what that burning smell was ;D
Post by alibongo on Sept 15, 2006 7:39:04 GMT 1
Thats your inflatable/vibrating sheep. Leave it alone, you will wear it out! ;D
Post by pablo on Sept 15, 2006 8:32:51 GMT 1
i use lard
Post by alibongo on Sept 15, 2006 16:47:05 GMT 1
Explains the burning smell...................
Post by pablo on Sept 15, 2006 21:39:22 GMT 1
stops em squeking tho
von
Post by von on Sept 15, 2006 22:09:23 GMT 1
Post by pablo on Sept 15, 2006 22:12:05 GMT 1
;D smooth talker...
Post by alibongo on Sept 18, 2006 9:57:42 GMT 1
Aint he?!?
Post by chrismac on Dec 10, 2006 18:15:08 GMT 1
Well guess what I got ;D
yep it a fully rebuilt Elsie ;D ;D ;D
Only been round the block a couple of times but seems better than ever ;D ;D ;D ;D
Post by scott on Dec 10, 2006 21:19:32 GMT 1
good news m8,got any piccy's yet
Post by guiri on Dec 11, 2006 3:28:34 GMT 1
two strokes,luv em and hate em .spend your dosh on the most expensive oil possible helps keep these things to a minimum .i thrash my ypvs to death and only pop head gaskets when weathers hot
Post by Dirtbag on Dec 11, 2006 9:56:08 GMT 1
Try removing the thermostat mate....theyre not much use anyway.....all they ever do is f**k up
Post by mellow on Dec 11, 2006 16:54:42 GMT 1
i thrash mine n temp always at about 1/4
Post by alibongo on Dec 11, 2006 17:02:25 GMT 1
Coz you use lube mate! ;D
Post by mellow on Dec 11, 2006 17:05:50 GMT 1
so thats wot it is ;D
