russktm
Finally on the road!!
Post by russktm on Jun 14, 2006 16:24:24 GMT 1
Hi everyone, I'm new to the site,and i'm in the middle of rebuilding a 250lc.I've got two 250 engines, one running in the frame, the others on the bench which i'm gonna convert to a 350. I've got 350 barrels and pistons, but do i have to change the 250 carbs, or just re-jet the carbs?? Will 350 ypvs carbs do the job? or do they have to be 350lc carbs (non ypvs).Any help would be gratefully received. thanks Russ.
Post by Norbo on Jun 14, 2006 17:06:57 GMT 1
Hi Russ. Welcome to the site.
You can run with 250 carbs but 350 or ypvs would be better. They do race on 250 carbs as they give more midrange. But on a road bike id go ypvs any will do 31k or 1ua carbs. What ever you use you will have to rejet to soot the bike . TZR 250 KR1 and RD A/C carbs are all ok and are 28mm.
russktm
Post by russktm on Jun 14, 2006 17:22:38 GMT 1
any ypvs carbs? jap or brazilian? thanks lads!!!!!!!
russktm
Post by russktm on Jun 14, 2006 17:28:29 GMT 1
are the 250 and 350 lcs crank and bottom ends, gearbox etc. the same? is the pistons barrels and carbs that are different? once again I thank you!!!!
russktm
Post by russktm on Jun 14, 2006 22:19:11 GMT 1
Cheers dirtbag, i've got both cdi an oilpump of a 350, thanks again lads! Im sure i'll have a few more questions before long. thanks again!
Post by scott on Jun 15, 2006 19:08:52 GMT 1
glad i red this,never knew the cdi's were different aswell :-/av to look out for 1 of them now
Post by Norbo on Jun 15, 2006 21:57:37 GMT 1
You will have to change the little end as well with a 350 top end the 250 one is to small.
Post by Deleted on Jun 18, 2006 19:03:21 GMT 1
got a cdi if your still after one as im puttin ypvs in mine
