Post by jacobeana on Mar 26, 2006 18:14:37 GMT 1
the glass in my master cylinder is leaking does anyone no how to fix it, f2 type
Post by jacobeana on Mar 26, 2006 18:46:18 GMT 1
not the same master cylinder still need help
Post by Norbo on Mar 27, 2006 11:15:28 GMT 1
A heat gun. The type with the solid stuff you feed in that might do it and still look clear ish
Post by K.B on Apr 19, 2006 21:21:15 GMT 1
Hi my master cylinder glass was leaking on my 250 LC and I fitted a secondhand cylinder glass from a old master cylinder.
Post by mellow on Apr 19, 2006 22:30:20 GMT 1
ok i been lookin at this..................on the F2 one........it looks 2 me that the glass pushes in from the outside coz theres an o ring behind it so all we need is a brave person or sum 1 with a spare to try n take the window out n see if its possible to get it out n fit new o ring n get it back in n e takers
Post by mellow on Apr 20, 2006 15:54:58 GMT 1
i would luv to baggy............but i do not have a spare if it goes tits up.but im 99% sure theres an oring behind the glass n the glass n o ring go in from the outside how else would mr yamaha have got it in
Post by K.B on Apr 20, 2006 20:32:14 GMT 1
Hi there is an o ring behind the glass and there is a metal clip inside the master cylinder. Pull the clip out and then you can push the glass out. I have done this on my 250 LC master cylinder and fitted a secondhand one and it ok.
Post by mellow on Apr 20, 2006 20:38:27 GMT 1
F2 ones are different m8 no clip or access from inside.thanks n e way
Post by jacobeana on Apr 23, 2006 21:35:50 GMT 1
I have a old f2 master cylinder that i will take a part to see how the glass seals will post when done
Post by mellow on Apr 23, 2006 21:48:16 GMT 1
good man................u deserve a gold star u know
Post by jacobeana on Apr 25, 2006 22:22:22 GMT 1
Post by mellow on Apr 26, 2006 22:21:56 GMT 1
oh dear well u know y..................its the old "supply/demand" scenario they can charge us loads coz we need brakes its like the pin bit in the front master cylinder...............in microfiche its all seperate parts but can u buy the bits thanks for tryin that though jocob
Post by jacobeana on Apr 30, 2006 22:05:00 GMT 1
Fixed it ;D Fixed it ;D Fixed it ;D Fixed it ;D Fixed it ;D Fixed it ;D Fixed it ;D ;D ;D ;D ;D ;D
Post by mellow on Apr 30, 2006 22:19:17 GMT 1
good man ;D do tell how
Post by jacobeana on May 1, 2006 21:26:35 GMT 1
Right here Goes
Leave the master cylinder on the bike or clamp in vice, if you leave it on the bike take the fluid out using a sringe like u get in a printer cartridge refill kit or borrow one from the local junkie
The glass and seal are stuck fast with crystilised brake fluid, you have to keep pressing the glass until it moves a small amount to brake up the gunge, then get a small blade screw driver and a stanley knife push the screw driver through the slot in side the master cylinder. push at the bottom of the glass when you have pushed the glass far enoiugh to get the stanley blade behind the lip in the glass it will slowley pop out. you can get a replacement seal from halfords in a pack for a quid Clean out the gunge then push the glass back in with the new seal ;D ;D ;D
Post by mellow on May 1, 2006 23:35:05 GMT 1
top man..........blue peter couldnt have done better ;D
Post by pablo on May 3, 2006 0:21:03 GMT 1
dead clever mate...
Post by mellow on May 3, 2006 10:08:40 GMT 1
15 if id have had 15 id still b asleep only had 1 then the barmaid walked past.............got a sniff of her apron..........that was it.gone ps..............me carrie anne n monica had a gr8 time last night pmsl ;D
Post by K.B on May 6, 2006 21:54:22 GMT 1
Its easy to fix that is what I did on my RD 250 LC master cylinder !!!
Post by pablo on May 7, 2006 1:02:13 GMT 1
read the posts mate he DID say so earlier...
Post by jacobeana on May 7, 2006 21:18:59 GMT 1
Problem is there is no clip on a F2 master cylinder so the glass fits a lot tighter and if you are no careful you will put the screw driver through the glass
loopy
Post by loopy on May 9, 2006 16:40:35 GMT 1
or the stuff baggy stuck his speakers up in his den with........... took all of his might to get the things off, was well stuck down, that stuff could even stick an elephant to the walls.....or a wilderbeast...........
Post by pablo on May 9, 2006 18:59:40 GMT 1
watta bout a rino sore arse loopy?...
