Post by scott on Mar 6, 2006 18:32:50 GMT 1
what wheels go straight into a lc,with or without changing swingarms & forks.i'm sure someone can help.this is to improve handling & braking.
Post by scott on Mar 6, 2006 21:17:58 GMT 1
would rather change swingarm & forks then.do rgv bits fit aswell as they fit onto a ypvs lc11.got a ypvs & lc don't know which one to change.
Post by Norbo on Mar 7, 2006 19:27:03 GMT 1
YPVS wheels fit well and you get a rear disk.
Post by vinze187 on Mar 7, 2006 21:32:40 GMT 1
but if you fit rear wheels only surely youd run into problems, chain rubbing the tyre? chain running and an angle? Youd definately need to run an off set front sprocket at least wouldnt you?
The Rgv bits dont fit so well onto the lc frame the shocker arrangement is worlds different. if you wanted to mod the frame a serious amount then it might fit in but youd be running a suspension set up that wasnt designed for that frame or swinger, im guessing you could get handling problems. the ypvs f2 mod to rgv is so much simpler, you can even do it with out modding the frame or swinger if you wish by using some adaptor brackets and bushes.
Post by Norbo on Mar 8, 2006 13:38:31 GMT 1
i would fit one of dirtbags ypvs,LC swingers in your lc and put a ypvs back wheel in and put a set of YPVS forks youks and fornt wheel in as well . Very simple and no frame mods needed .
Post by vinze187 on Mar 8, 2006 17:00:56 GMT 1
but what about the chain alignment? would it still be okay?
Post by Norbo on Mar 8, 2006 18:58:44 GMT 1
but what about the chain alignment? would it still be okay? There is no problem with this . all you need is the front sprocket spacer from a ypvs and your off . Have a look at Chris web's lovely black LC i have just added it to the gallery .He has ypvs ends on his bike .
Post by scott on Mar 8, 2006 19:22:44 GMT 1
many thanks for the advice chaps
Post by scott on Mar 9, 2006 22:58:31 GMT 1
can running gear off any rgv be fitted to a ypvs lc11,because i can get my hands on a 1990 L model.
Post by Norbo on Mar 11, 2006 0:33:49 GMT 1
Yes it can you can make anything fot your bike with anough welding and messing about.
Post by nuttytart350 on Mar 11, 2006 14:43:10 GMT 1
Thats wot i'm relying on with these FZR 400 parts i've got
Post by nuttytart350 on Mar 11, 2006 14:54:39 GMT 1
Talking of which......if anyone wants a front end with a fatter front wheel I have an extra one going......legs 32 inch / wheel / spindle / speedo drive.......100mm spacing on caliper mountings would take R1/6 blue spots.........I dont have yokes or discs
Post by mellow on Mar 11, 2006 17:09:59 GMT 1
u got long legs int ya ;D
Post by nuttytart350 on Mar 12, 2006 1:07:43 GMT 1
I have as it happens......smooth / shiney / and no pits
Post by mellow on Mar 12, 2006 12:40:28 GMT 1
sorry i cant follow up that response
Post by scott on Mar 12, 2006 12:56:22 GMT 1
i might need a set of forks for an fzr 400,i can get everything else for my ypvs progect.would you sell seperate.
Post by nuttytart350 on Mar 12, 2006 17:25:20 GMT 1
You just want the legs then scott
Post by mellow on Mar 12, 2006 18:09:04 GMT 1
then ul b legless ;D
Post by nuttytart350 on Mar 12, 2006 21:55:32 GMT 1
To be sure...I will that.....
Post by scott on Mar 12, 2006 23:31:04 GMT 1
need complete set of forks
Post by nuttytart350 on Mar 12, 2006 23:38:44 GMT 1
Am I being dim here.....do you want just the fork legs or legs + spindle or legs + spindle + speedo drive or what
Post by scott on Mar 12, 2006 23:45:44 GMT 1
picking up fzr 400 bits up tomorow not sure about spindles & speedo drive,i will post a mesage tomorow,sorry for the confusion
Post by nuttytart350 on Mar 12, 2006 23:52:17 GMT 1
oh OK
