Post by soccersmyth on Sept 14, 2010 10:40:50 GMT 1
Does anyone know the koyo bearing numbers for the headstock bearings to suit a 4L0 frame using ~RGV 250 M yokes Can get em very cheap - all i need is the numbers Thanks in advance
Post by midlifecrisisrd on Sept 16, 2010 17:09:18 GMT 1
Does anyone know the koyo bearing numbers for the headstock bearings to suit a 4L0 frame using ~RGV 250 M yokes Can get em very cheap - all i need is the numbers Thanks in advance If the stem is the same as YPVS then standard RD taper bearings will fit as the stems are the same diameter, just the spacer as gary said. Some even use the origional bottom bearing cup. Steve.
Post by soccersmyth on Sept 16, 2010 17:37:01 GMT 1
Got another 4L1 frame that needs blast / coating etc....so will put new uns in anyway. Am gonna use this for the hybrid and put the 4l1 frame that has matching cases that i was gonna use up in the loft for a rainy day Had taper bearing in it but not much room to get the ole chisel in to drift em out I'll just have to bite the bullit and buy them and the spacer of norbo. Just waiting for him to get back to me !!!!!!!!
Post by nikfubar on Oct 3, 2010 20:41:47 GMT 1
The original ball race cup works a treat just fit it flat side up & it's 6mm thick ;D I've found the best place to buy all types of bearings on line is shop.marksman-ind.com/headrace---steering-bearings-13-c.aspand they sell bearing seals, if you don't know the bearing numbers all you need to know is the internal & external diameter & thickness then you can find the one you are after
Post by soccersmyth on Oct 4, 2010 0:12:22 GMT 1
4l1 frame that has matching cases that i was gonna use up in the loft for a rainy day well the rainy day has arrived john ;D ;D It has butchers
