Post by jessy03 on Sept 4, 2010 20:13:32 GMT 1
Well, all done,apart from final jetting. just fitted sv650 shocker also redone the top end as it was knocking, it turned out to be worn powervalves. it has a mild tune, skimmed head, pwk28 carbs, ignition +2. took it round the block this morning several times to set it up and would only run well with no air box lid nor filter, set up is 38 pilots, 148 mains and needle on the middle clip, is this normal? any advice on the jetting would be greatfully welcomed. jessy
Post by lcowner on Sept 4, 2010 20:22:06 GMT 1
some bike mate u done sum job on it...
Post by billy on Sept 4, 2010 20:50:08 GMT 1
That's one helluva bike, looks f***ing gorgeous! What pipes are those btw? Never seen those before, they look the schnitzl fritzl too.
Post by philthat on Sept 5, 2010 21:34:25 GMT 1
I hardly ever post comments on any of the forums, but I've got to say that in my humble opinion, that is the best looking LC that I have ever seen. I know that are many with the same front and rear ends etc , but there is something about that bike, perhaps the colour scheme, perhaps the exhausts or perhaps its the white gully seat, I have to say once again in my own humble opinion that it all comes together perfectly and that makes me want to have one just like it. Well done sir.
Post by bubba on Sept 5, 2010 21:47:14 GMT 1
iy that is a stunner! bet your on cloud nine with how that has turned out! well done top notcher that!
Post by bubba on Sept 5, 2010 21:53:18 GMT 1
just had to add they are the best looking pipes i have seen on a lc
Post by richardroberts on Sept 6, 2010 19:30:31 GMT 1
looks well m8 top job
Post by oldelsieboy on Sept 6, 2010 19:50:52 GMT 1
Cracking bike Jessy, you may think its finished but it aint, they never are Do you mind if I copy the photo to the LC Club GalleryOEB
Post by jessy03 on Sept 6, 2010 22:07:39 GMT 1
Thanks for the kind words, yes I'm very happy with it now, I had a few sleepless nights on the way though. Gibsons done the exhausts and few other bits, bit of a long wait though. yes Nigel it will never be finished I'll always be tinkering with it and you're welcome to put it in the gallery if you thinks it's worthy. Thanks Jessy
Post by scott on Sept 6, 2010 22:17:12 GMT 1
real nice bike m8,top job . i heard about the sv shock for an lc,is it a direct replacment,same length and fixing hole sizes?
kevemo
Post by kevemo on Sept 7, 2010 8:51:23 GMT 1
now that is wot an lc should look like theres to many standard ones out there for my liking
hondablade
2 wheels ~ 2 Strokes
Post by hondablade on Sept 7, 2010 14:21:14 GMT 1
Just to add to all comments so far, im a standard man all the way olive drab and all that stuff, but if i had a custom type this would be the one... I like the way youve kept standard indicators/rad cover with all the aftermarket stuff aswell.... great bike love it.
Post by jessy03 on Sept 8, 2010 13:37:20 GMT 1
Scott, the sv650 shock is about 25mm longer than the std lc, you need to drill out the lower mount to 12m and the top is 10mm so you need a spacer10-12mm, I was lucky and found a spacer at work, then it just bolts in. you can pick them up cheap off ebay nearly new ones. Jessy
Post by LC'Adam on Sept 8, 2010 21:10:09 GMT 1
As per the thread about the guy killed stealing a bike. This bike is the reason they steal them lol No, on a serious note, congrats mate, one of the best hybrids I have ever seen.
Post by looey on Sept 8, 2010 21:44:48 GMT 1
Bl**dy lovely, would I like that !
Post by bubba on Sept 8, 2010 21:47:31 GMT 1
jessy will you put up a video of it running giving it a few blips i bet them pipes sound crackling great ;D
jay20t
Post by jay20t on Sept 13, 2010 18:06:05 GMT 1
That is absolutley gorgeous hpoe mine will look similar 1 day could be a while though as ive only got the rgv front and rear ends at the mo , no bike yet lol
Post by scott on Sept 13, 2010 18:25:10 GMT 1
Scott, the sv650 shock is about 25mm longer than the std lc, you need to drill out the lower mount to 12m and the top is 10mm so you need a spacer10-12mm, I was lucky and found a spacer at work, then it just bolts in. you can pick them up cheap off ebay nearly new ones. Jessy thanks jessy.i had read that they fit and does'nt take alot to fit them then and like u say they are really cheap to buy.cheers m8 have some karma
Post by 2942matt on Sept 19, 2010 20:18:03 GMT 1
Gorgeous, id like to hear it running the pipes are the best ive seen
Post by jessy03 on Sept 20, 2010 20:36:10 GMT 1
ok ok, i'll put a video of it running up. you might need some ear plugs though jessy
Post by andygraham on Sept 20, 2010 21:43:21 GMT 1
stunning bike! takes the breath away
Post by nikfubar on Sept 21, 2010 7:56:09 GMT 1
I think you need to up jet the PWK28s. I run basically the same set up except with foam pod filters and I'm using 42 pilot 160 main JJH needles on middle clip, air screw 1&1/4 turns out. When I was running 150 main it had no top end & was nearly seizing from running too lean. Cool hybrid credit to ya
Post by jessy03 on Sept 21, 2010 19:36:32 GMT 1
thanks Nick, I'll put some 160's in What Plug do you use? I put in some BR10ES jessy
Post by mick1664triumph on Sept 21, 2010 19:52:03 GMT 1
I am a standard man, but that is A WORK OF ART
Post by Norbo on Sept 21, 2010 20:51:14 GMT 1
Thats cool as fick mate
Post by stinkerd on Sept 29, 2010 8:10:21 GMT 1
Dear Jessy, Nice bike you have there! I'm currently trying to finish my own LC / RGV banana conversion. Can you tell me what ride height you have used for the back side? See also my own topic. Further I see you are using a Tyga rear set?: Can you tell me the exact setup/specs? Thanks in advance Marcel, the Netherlands
Post by bare on Oct 2, 2010 3:50:26 GMT 1
real nice bike m8,top job . i heard about the sv shock for an lc,is it a direct replacment,same length and fixing hole sizes? Been there done that with the SV650 shocker. It CAN be drilled out to exactly match the OEM LC length. Bigger problem is that the spring is of a higher rate than the LC one (no real surprise the sv is a much heavier machine) BUT.. the Cheap Ass Chinese (yes!!) Shock hydraulics are even weaker/ shittier than the tired ones in my collection of 30 yr old LC shocks. In english a Crap upgrade ONLY redeeming feature is these are almost Free on Ebay as SV owners can't get rid of them fast enouigh. Now i know exactly why A complete Waste of Effort ... in my direct experience... the LC's handling becomes Much worse. MY Valvie engine using stock airbox/filter though.(But little else is stock :-) on PWKs'; uses 40 Air jets and 130 Mains , on additional 1.5% Premix and is Running Rich.. proven by plug chops. Can't imagine needing yet More fueling.. barring a faulty setup.
