Post by midlifecrisisrd on Jun 26, 2010 15:14:14 GMT 1
Hi, got a pair of powerjet carbs one marked 1UA oo and the other 1UA 10. Is this a pair ie left and right id numbers or different kinds?
Steve.
Post by mellow on Jun 26, 2010 18:55:26 GMT 1
im goin for different types m8. Think they should be 1UA 00
Post by dredge3 on Jun 26, 2010 19:06:39 GMT 1
im goin for different types m8. Think they should be 1UA 00 I had 2 x 1ua 10
Post by midlifecrisisrd on Jun 26, 2010 22:07:45 GMT 1
im goin for different types m8. Think they should be 1UA 00 Better than the pair I first bought 1 x 1ua and 1 x 4CE Not having much luck here. Steve
Post by Deleted on Jun 27, 2010 18:01:24 GMT 1
Mine are the same as yours. My nearside carb is a 1UA00 and my offside carb is a 1UA10. According to the parts list, they should be both 1UA00.
Seems to go alright, though.
Post by midlifecrisisrd on Jun 28, 2010 8:54:58 GMT 1
Mine are the same as yours. My nearside carb is a 1UA00 and my offside carb is a 1UA10. According to the parts list, they should be both 1UA00. Seems to go alright, though. I'm with you, I'll put them on and see how they go. Plug chop will soon tell. Steve.
Post by Deleted on Jun 29, 2010 22:55:06 GMT 1
Noticed in the Haynes manual - if it's to be believed - that if the powerjet is a screw fit, then it's from the R model (the F2 powerjet is a push fit - 1UA 00) and the right-hand carb could have a powerjet size of 50.
The F2 right-hand carb should have a powerjet size of 60.
That would make sense to me. I have replaced my right-hand 1UA 10 carb (screw fit powerjet) with another because it wasn't pulling to high revs, and now it does. I guess the carb first carb I had in had a powerjet size 50 and the one I have in now probably has a powerjet size 60 but I'll have to investigate.
Post by midlifecrisisrd on Jun 30, 2010 16:12:01 GMT 1
Noticed in the Haynes manual - if it's to be believed - that if the powerjet is a screw fit, then it's from the R model (the F2 powerjet is a push fit - 1UA 00) and the right-hand carb could have a powerjet size of 50. The F2 right-hand carb should have a powerjet size of 60. That would make sense to me. I have replaced my right-hand 1UA 10 carb (screw fit powerjet) with another because it wasn't pulling to high revs, and now it does. I guess the carb first carb I had in had a powerjet size 50 and the one I have in now probably has a powerjet size 60 but I'll have to investigate. Got a set of R carbs and they are marked 4CE so not that, also the R has powerjets about25-30 if I remember right. Interested to find out if the powerjets are different on 00's and 10's. Steve.
