Post by scott on Oct 2, 2011 0:37:57 GMT 1
absolutly stunnin m8 8-)as for it livin upto other restro's on here i think your the 1 to follow m8 8-)from what it was to what it is now m8 is well
Post by mellow on Oct 2, 2011 12:17:04 GMT 1
m8 urs is spot on.all the stainless parts u made.i might even contact you for some next year ;D
Post by Deleted on Oct 2, 2011 12:54:26 GMT 1
well done, must be very satisfying to achieve such a professional looking finish when you have done it yourself,bravo, if i can get mine this good, i will be chuffed,.
Post by kennyroberts on Oct 10, 2011 22:41:32 GMT 1
self made, fitted the end of the rear brake cyliner linkage. im just looking forward to the show at stafford now for a few bits.
Post by aaron on Oct 10, 2011 22:44:44 GMT 1
And the Bar gets higher
Post by kennyroberts on Oct 10, 2011 22:51:03 GMT 1
just found out what the caliper parts are that i need (pics a few lines above !) parts FL (front left?) and RO (rear something ...offside?), both got screwed up trying to remove the bleed nipples !!!! :-(
Post by kennyroberts on Oct 10, 2011 23:21:01 GMT 1
fuel tap clean up , stripped, and masked , shotblasted with glass, and sprayed with petrol resistant laquer just gotta get a fuel tap repair kit
Post by kennyroberts on Oct 10, 2011 23:35:57 GMT 1
and moving on to the forks, a lot of polishing to do yet ! but its a start
Post by aaron on Oct 11, 2011 19:24:21 GMT 1
Do you have your own blasting setup?
Post by kennyroberts on Oct 11, 2011 21:30:19 GMT 1
aaron, i used to work as an aircraft engineer, specifically restoring and rebuilding parts for spitfire aircraft,, and i still use the kit at the old workshop at Supermarine , im lucky enough to still get access to lots of kit, including tig, gas and arc welding, machine shop for milling and turning, as well as a big blasting cabinet etc, so i count my blessings for that !, i try to save bits of work up and have a few hours there over a weekend, and in turn ill do an hour or two on their stuff .......otherwise i feel guilty imposing on them :-), i dont like summat for nowt !, i try to pay my way in return with a favor . i would like my own little blaster at home though, im surprised just how much i use them, how about you?
Post by kennyroberts on Oct 14, 2011 21:08:06 GMT 1
got a few more little bits sorted, i turned down the old tatty bar ends and the allen bolts on the lathe, and then a polish, made the 2 clutch/brake lever inserts and heat treated and hardened them to black!plus the bolts next stop....stafford classic bike show !
Post by aaron on Oct 16, 2011 13:13:01 GMT 1
aaron, i used to work as an aircraft engineer, specifically restoring and rebuilding parts for spitfire aircraft,, and i still use the kit at the old workshop at Supermarine , im lucky enough to still get access to lots of kit, including tig, gas and arc welding, machine shop for milling and turning, as well as a big blasting cabinet etc, so i count my blessings for that !, i try to save bits of work up and have a few hours there over a weekend, and in turn ill do an hour or two on their stuff .......otherwise i feel guilty imposing on them :-), i dont like summat for nowt !, i try to pay my way in return with a favor . i would like my own little blaster at home though, im surprised just how much i use them, how about you? I wish! Just starting to get my workshop together and spending far to much money.. your a lucky man.
Post by kennyroberts on Oct 24, 2011 22:51:06 GMT 1
latest purchase from the stafford show, £5 buys an Fz 750 chain guard (same as F2 ypvs) it has a couple of very minor scuffs, but wet and dry down the grades and t cut ,then plastic polish and a little clear laquer will have this like new, not forgetting a new chain guard sticker !,......I Know NOS are only £25 ish, buy where's the fun in that ?
Post by JonW on Oct 25, 2011 0:31:37 GMT 1
Ohh now thats shiney! nice work
Post by scott on Oct 25, 2011 20:37:37 GMT 1
nice before and after on the chainguard
Post by kennyroberts on Nov 16, 2011 22:07:55 GMT 1
my latest purchase !!!!! and in kenny roberts yellow too!!! guess what im up to soon !
Post by Deleted on Nov 16, 2011 22:52:17 GMT 1
are you trying to corner the vinegar futures market,lol
Post by kennyroberts on Nov 28, 2011 23:28:06 GMT 1
sorted out my new downpipes to graft onto the old silencers (the old downpipes were pitted) so i need to drop the engine into the frame and set these pipes up so all the joints line up, then out with the welder!
Post by mellow on Nov 29, 2011 22:25:37 GMT 1
Im impressed as always m8 but bloody hell they are thick metal are they normally that thick
Post by kennyroberts on Nov 30, 2011 19:16:25 GMT 1
its the thinnest i could get at the closest dim that could also be bent with the right size mandrel,
but at least it wont rust through,:-) recon ill lose about 10 bhp / 20mph with the extra weight ..LOL
Post by marsbar350 on Nov 30, 2011 23:33:03 GMT 1
hi kenny what is the diameter of the pipes? with the aid of your drawing i could get some made up at work most of our tube is coated and between 1.5 and 2mm thick
Post by marsbar350 on Nov 30, 2011 23:36:27 GMT 1
just looked again 45mm o/d will see at work 2moz but im pretty sure we use that diameter
Post by kennyroberts on Dec 1, 2011 0:18:54 GMT 1
the original pipes have a big taper so are a lot smaller one end than the other, i kind of took the average and it fitted what i could get. 42.2mm OD x 2.7mm Wall that I can bend on a 4" CLR to 116 degrees. and it works a treat, .....a bit thick, but its ok ill create a step joint in the clamp ends and weld this together, and the other end ill weld on the expansion pipe, and on the far end ,a plate for a bolt on end can , i just need some time to get on the welder, but i must remember to plate the exhaust clamps and slide them on before welding the exhaust together.!!!!!!otherwise that would be a DOH! moment.
Post by jonnyboybon on Dec 1, 2011 17:51:16 GMT 1
absolutly stunnin m8 8-)as for it livin upto other restro's on here i think your the 1 to follow m8 8-)from what it was to what it is now m8 is well I'll second that
Post by marsbar350 on Dec 1, 2011 18:06:24 GMT 1
had a look at work today weve got 44mm o/d and 46mm o/d 2mm and 1.5mm thick wall stainless and mild steel ive got an old pipe which i can cut the down pipe off.i can swell a collar to the inside for a perfect fit to the barrels we have thousands of different flanges so matching to the lc shouldnt be a problem the downpipe will go on the vector where measurements taken put into the computer and bends and cuts pipe to size once the programme is in.makem when i want watch this space ;D
Post by kennyroberts on Dec 1, 2011 22:47:52 GMT 1
Mars bar are you gonna do your own?, if so, good luck, im gonna enjoy doing mine,
Post by kennyroberts on Dec 31, 2011 1:17:24 GMT 1
well, christmas has come and gone, and nothing new for my bike from santa ! :-( just a tap and die set and nut and bolt extractor set (amongst the smellies and clothes etc) and i have had no chance to get into the garage , i did get time to add up the true cost of all the bits to get my bike as i want it ...........wish i didnt, at £1467.00!!!!!!! ill be at this untill 2019! happy new year to you all, and may all your projects kick up first time !
Post by kennyroberts on Jan 28, 2012 22:33:20 GMT 1
i have finally sent my frame off to the powder coaters, i had gloss black in mind untill i saw another customer collecting something interesting from the coaters, (a car component) when he saw it, he wanted to immediately take it home to bed and love it ! i had to agree! so, i had to copy, i have never seen a bike frame done in this stuff ! so ..........im nervous and excited ! , watch this space , ill be picking it up in a few days ! take your bets !
Post by JonW on Jan 29, 2012 7:35:50 GMT 1
Cool, I hope its ceramic....
Post by kennyroberts on Jan 30, 2012 21:25:09 GMT 1
well, things have not gone to plan, but nevermind, i think i found out just in time! i opted for something a bit different when i saw a black crackle powder coat,i thought....THIS is for me ! it turns out its not best suited for bike frames, its ok for engine parts and stuff under bonnets etc, lucky i phoned up the powder coaters to have a chat over my option, so, its back to plain old gloss black, pitty ...it looks awesome (heres a pic of some crackle black off the web) but im sure when i get that shiney black frame back, ill be chuffed its no longer pitted and rusty etc.
