Post by skaterboy on May 29, 2010 0:30:24 GMT 1
arrdee
Post by arrdee on May 29, 2010 10:37:33 GMT 1
No disrespects to the chap selling this one on eBay, but why don’t you get your original one fully overhauled professionally and then you know what’s been replaced for sure? Gav
Post by bryan on May 29, 2010 12:52:20 GMT 1
with Gav on this, the crank is the last bit to remove when you strip an engine so make sure its done properly the first time.
Post by spondonchris on May 29, 2010 14:36:38 GMT 1
Agreed, i always use Grampian motors in Crosby Merseyside.
Post by nikfubar on May 29, 2010 22:43:58 GMT 1
Don't know what you are all on about there's nothing wrong with welded cranks I'm not bitter, no sir
Post by johnlc on May 29, 2010 22:58:24 GMT 1
I have a welded crank in mine have had no problems so far .Was welded as i had missed a gear and revved it sky high twisting it
Post by nikfubar on May 29, 2010 23:29:39 GMT 1
Wish I'd had the same welder that did yours, thats how mine twisted
Post by bare on May 30, 2010 3:06:48 GMT 1
there's NO buying any Ebay crank of any description. But hey! it's Your $$. A decent weld job is surprisingly tough and a Zeel Box's rev limiter prevents 'misssed shift' screw ups. Double safeties.
Post by skaterboy on May 30, 2010 16:53:30 GMT 1
Post by johnlc on May 30, 2010 20:01:57 GMT 1
I would only buy a crank from ebay to rebuild ,you know what you have then .I have a rev limit of 10,500 rpm just to be safe nowadays
Post by bare on Jun 1, 2010 17:27:18 GMT 1
So did I.. It's proving too high for reasonable durability. iMO. Now it's at 10k
Post by skaterboy on Jun 4, 2010 3:58:07 GMT 1
Hi Gang Can you look at my last post are these measurment correct for checking the crank . I feel an immenant expensive engine build very soon. ;_) . Ta Mark
Post by dredge3 on Jun 4, 2010 8:23:26 GMT 1
3am dont you sleep They are all in the Haynes. big end side clearance.25 to .75mm con rod small end deflection .36 to .98 service limit 2mm
Post by skaterboy on Jun 15, 2010 16:03:58 GMT 1
Hi Maybe a silly question but please humour me is the 4L0 RD350LC AND THE 4L1 250 LC crank shaft the same , led to believe the stroke is the same Mark
Post by spondonchris on Jun 15, 2010 16:33:06 GMT 1
Yes its the same bottom end full stop.
Post by skaterboy on Jun 19, 2010 22:24:26 GMT 1
Hi Gary I am looking at building a 4L0 engine and would be intrested in fitting a 31K crank. I was just going to get a 4LO crank rebuilt to match a nice set of tuned barrels but would like to improve on the engine if possible. I wondering if this is something you have done and if so what sort of work is involved and who did it ?? .. Thanks Mark
