Post by dredge3 on May 25, 2010 20:56:34 GMT 1
Just got a full gasket set, with no crankcase gasket.That is for the top and bottom halves to join. Do you use sealant, Noticed loads of rubber rings. Are those for the dowels between the 2 halves. Also the main wiring loom that runs along top, near the clutch arm.It runs from the inside of the case into the left hand stator cover. It hasn't got a grommet, so water can run inside. Do they have grommets. Ill post picture if its not clear
Post by dredge3 on May 25, 2010 21:38:46 GMT 1
Cheers Gaz. Not sure if a grommet will fit, due to old owner rewiring it all like a muppet. Its loads of wires with 3 rolls of insulation tape wrapped round it. May use sealant. Cant find the grommet on the net as yet
Post by dredge3 on May 25, 2010 21:58:26 GMT 1
I will mate. Just reading about yambond v threebond. threebond is megga £. 1194 replaces 1104 (no lead) 1211 is stronger, most use this for crankcases. Yambond 4 is much cheaper
Post by mellow on May 25, 2010 22:24:59 GMT 1
got mine from there.cheapest ul get it that is
Post by dredge3 on May 25, 2010 22:48:51 GMT 1
I typed in threebond and it came up with 1 result for 1194 @ a price double that. Just tried again and got a page full. Thanks again
