Post by peddrotzr on May 17, 2010 18:34:27 GMT 1
Hi, Can anyone help with the gearbox ratios for a RD350 LC 4LO. Or do you know if the output gearbox shaft for a 4LO is the same as that on a RD350 YPVS ?
Many Thanks
Peddro.
Post by oldelsieboy on May 17, 2010 18:42:41 GMT 1
Hi, Can anyone help with the gearbox ratios for a RD350 LC 4LO. Or do you know if the output gearbox shaft for a 4LO is the same as that on a RD350 YPVS ? Many Thanks Peddro. According to the Haynes Bible the ratios are; 1st - 2.571 : 1 2nd - 1.778 : 1 3rd - 1.318 : 1 4th - 10.83 : 1 5th - 0.962 : 1 6th - 0.889 : 1 AFAIK the YPVS gearbox is the same as 4L0/1 OEB
Post by peddrotzr on May 17, 2010 18:50:41 GMT 1
Thanks for the information & the very quick reply. However I have been informed that the shafts are different.
Has anyone got an Output shaft for a RD350 YPVS please?
Best regards
Peddro.
Post by Norbo on May 21, 2010 16:22:23 GMT 1
I have a compleat gear box £45 plus post
