hondablade
2 wheels ~ 2 Strokes
Post by hondablade on May 13, 2010 19:26:59 GMT 1
Just a quickie.... What 2 stroke oil does everyone run? Im using yammalube 2 stroke at the moment, seems to be o.k but not easy to get hold of as no close local yam dealers and not easy to find online, although i did find a 55 gal drum for £600!!! Bit too much though.
Been looking at motul 2 stroke, i use the 10W 30 motul gearbox oil and thats great stuff.
Any ideas thanks...
Post by mellow on May 13, 2010 19:31:04 GMT 1
Post by oldelsieboy on May 13, 2010 19:31:41 GMT 1
Rock Oil PP2 semi synthetic
OEB
hondablade
Post by hondablade on May 13, 2010 19:42:52 GMT 1
Cheers for that, havent seen that thread before. Ta.
Post by dredge3 on May 13, 2010 23:49:51 GMT 1
Castrol has been around for years. i used to use Castol R in my crosser, then again it seized up...smells nice. I use Halfords 2tt or what ever its called. I will go pre mix after engine re build, so my local crosser shop is the best for that advice
Post by Norbo on May 14, 2010 8:00:36 GMT 1
All the R oild do smell nice but remember they are primix only and they will oil up the plugs if you dont thrash a lot"the plugs oil up " Remember they are mainy for hi reving race engines.
I run Motul oils i fined them very good.
Post by ringding on May 14, 2010 17:56:50 GMT 1
I've used the Silkolene range for years with no problems, Comp2 stuff. Recently swapped to TTS Power 1 (Castrol) and that seems OK too. I doubt there is too much to pick and chose between the big name brands.
Post by mellow on May 14, 2010 20:34:45 GMT 1
mind you saying that at the BBQ robbo and the pool sharks were running something else n it smelled similar to castrol R That was the gasses after the burgers n beer m8
gadget
Post by gadget on May 14, 2010 20:59:13 GMT 1
Castrol TTS power 1, very good stuff, easy to get hold of, and not a bad price. ticks all the boxes for me ;D
hondablade
Post by hondablade on May 15, 2010 10:50:40 GMT 1
i went to my local suzuki (nearest dealer to me) and bought that motorex oil of switzerland stuff instead, (semi synthetic), smokes like a mofo when you open it up hard, poor cars behind me!! Never seen a two stroke smoke so much, easy 10 times as bad as when it had yamalube in it lol!!
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on May 16, 2010 8:26:17 GMT 1
TTS IS GOOD
